Nie daj się oszukać, sprawdź VIN i historię
Re: Nie daj się oszukać, sprawdź VIN i historię
Mam prośbę o rozkodowanie mojego busika bo coś mi się wydaję że nie wszytsko sie zgadza ze stanem faktycznym.
WV2ZZZ70ZVH127075
Dzięki z góry.
WV2ZZZ70ZVH127075
Dzięki z góry.
[b]VW Caravelle LONG 2,5 TDI ACV[/b] (2011-...)
[b]Audi A6 C4 Avant 2,5 TDI AEL 6-gear[/b] (2009-...)
[b]Audi 80 GTE[/b] (2006-2009)
[b]VW Golf mk2 1,3[/b] (2005-2006)
[img]http://republika.pl/a_glasgall/Allegro/AUDI.jpg[/img]
Kod: Zaznacz cały
Vehicle Identification No. WV2ZZZ70ZVH127075
Model Designation transp. caravelle
Model TR
Date of production 07.04.1997
Model year 1997
Sales type 7DK2K2
Engine code ACV
Transmission code AFK
Axle drive 5S
Interior trim code UE
Roof color T7
Exterior color / Paint Code T7 / 902
Activated carbon canister 1E0 Without activated charcoal canister
Additional air-borne noise suppression measures 1J2 Sound deadening package and additional enclosures for some units
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Additional ventilation system 7J0 Without additional ventilation system
Air bag 4UE Air bag for driver and front seat passenger
Air cleaner (engine) 1L0 Standard air cleaner
Ambulance seat for medical staff 5JA Without ambulance seat for medical staff
Antennas 8L8 Inside-windshield antenna
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Armrests for front seats 4S1 Armrests for both front seats
Auxiliary heating 9M5 Auxiliary heater
Batteries J1D Battery 380 A (72 Ah)
Body style K4C Bus
Bolt-on kit 6GA Without add-on kit
Brackets 3P0 Without bracket for first aid kit and warning triangle
Brake type, front 1LU Disc brakes, front
Braking systems 1AE Electronic differential lock (EDL/ABS)
Bumper 2JG Body-colored bumpers
C-rails 6L0 Without C-rails
Catalytic converter control 8KA W/o catalytic converter warning light
Center high-mounted stop light 8R0 Without center high-mounted stop light
Child lock 4H2 Child lock for sliding doors in passenger compartment
Climatic zones 0Y1 Standard climatic zones
Clutch actuation 1K3 Hydraulic clutch actuation with over-center spring
Component part sets with country-specific design requirements B0X Component parts set, complying with vehicle type for Germany, various parts
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Compressor 2AA Without compressor or preparation respectively
Cruise control 8T2 Cruise control system (CCS) electronic
Cup holder 4M1 Cup holder in cab
Curtains/roller blinds 5G0 Without curtains
Dashboard 4N1 Padded dashboard
Delivery equipment 2A0 Without delivery equipment
Different vehicle equipment 5EA Without different vehicle equipment
Differential lock 1Y0 Without differential lock
Door and lid locking system 4F4 Central locking system
Door and side trim panels 3LQ Door trim panel
Door pockets, front 3YB Door pockets, front
Doors, cab 0D1 Cab doors
Doors, passenger/load compartment, left 5Q2 Sliding door left in load/passenger compartment
Doors, passenger/load compartment, right 5R2 Sliding door right in load/passenger compartment
Drive layout 1X0 Front wheel drive
Engine specifications M9M 5-cyl. diesel engine 2.5 L/75 kW TDI distr. inj. pump, turboch., interc., EGR base engine is T7K/T8S
Equipment levels A8C Comfort equipment
Final drive/gear ratio 0ZN Transmission ratio, high geared
Floor coverings in cab 5AD Carpet floor covering in cab
Floor coverings in passenger and load compartment 5BF Carpet floor covering in passenger compartment
Fourth row of seats 3WA Without bench seat
Frame forestructure AC1 Long frame forestructure
Fresh air unit/air outlet 6LD Fresh air unit with center outlet and recirculation door, without load/ passenger compartment ventilation
Front Assist 6K0 without Front Assist/without city automatic emergency braking
Front fog light/additional headlight 8WA Without front fog light
Front seat, left 3TQ Left swivel seat in cab with lumbar support
Front seat, right 3SQ Right swivel seat in cab with lumbar support
Front side window for load or passenger compartment, left 4DD Side window in heat-insulating glass in load/passenger compartment, front, left
Front side window for load or passenger compartment, right 4ED Side window in heat-insulating glass in load/passenger compartment, front, right
Front stabilizer 0AB Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Generators 8GL Alternator 120 A
Headlight 8BB Halogen headlight for driving on the right
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AB Manually controlled air conditioning
Hinges for side and tail gates 5V0 Without hinges for side and tail gates
Hood and trunk stay 5NC Standard tailgate stay
Horns 8Y1 Two-tone horn
Hydraulic pump 2BA Without hydraulic pump
Identification lights, roof 9KA Without identification lights
Identification plates 1EC Special identification plate
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Interference suppression 8E0 Without interference suppression
Interior light in driver compartment 9GB Interior light with switch-off delay and door pillar switch
Interior lights, passenger and load compartment 9CC Two standard interior lights in passenger/load compartment
Interior noise suppression measures 3W6 Additional interior noise suppression
Invalid chair 5PA Without invalid chair
Lashing rings/rails for load restraint 6B1 Lashing rings for load restraint
Left exterior mirror 3BS Left exterior mirror: aspherical, electrically adjustable and heated
Left vanity mirror 4SD Left vanity mirror, illuminated
Light assistance system 8G0 Without light assistant
Lock operation for tailgate/trunk lid 4E3 Without tailgate release lever inside
Malfunction display 9HA Without additional malfunction display
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Mounting fixture for oxygen bottle 5P0 W/o mounting fixture for oxygen bottle
Mud flap 6N0 Without mud flaps
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 0NB Nameplate set in base trim
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Partition 3CA Without partition
Payloads 0J2 Standard payload
Pickup bodywork/cargo area 5HA Without pickup bodywork/cargo area
Preparation for identification lights 9QA Without identification light preparation
Radios 8AD Radio "gamma"
Rear fog light 8TC Rear fog light for driving on the right
Rear gates/tailgate 3RC Trunk lid with window aperture
Rear headrests 3Q2 Rear headrests articulated and height-adjustable
Rear side window for load or passenger compartment, left 4FD Side window in heat-insulating glass in load/passenger compartment, rear, left
Rear side window for load or passenger compartment, right 4JD Side windows in heat-insulating glass in load/passenger compartment, rear, right
Rear stabilizer 0BA Without rear stabilizer
Rear window insert 4HF Rear window in heat-insulating glass, heated
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Restraint systems, front 3QC 3-point seat belts, front
Retaining cables for tail and side gates 5T0 Without retaining cables for tailgate
Right exterior mirror 3AF Right exterior mirror: convex, electrically adjustable and heated
Right vanity mirror 4TD Right vanity mirror illuminated
Roof insert in cab 3EF Sliding/pop-up glass sun roof in cab (operated electrically) with sunblind
Roof insert in driver's/load compartment 3JA Without roof insert in load and passenger compartment
Roof interior trim 5CH Roof interior trim, comfort molded headlining in cab and passenger compart.
Roof turn signal lights 9H0 Without roof turn signal lights
Roof types 3R0 Standard roof
Seat belt check 9P0 Without seat belt reminder
Seat belts for first row of seats passenger compartment 4PE 2 3-point seat belts and one static lap belt in first row of seats
Seat belts for second row of seats passenger compartment 4RE Two 3-point seat belts and one static lap belt in second row of seats
Seat belts for third row of seats passenger compartment 4VA Without seat belts in third row of seats
Seat covering N0F Woven fabric seat covering
Seat heater 4A0 Without seat heater
Seat storage trays, first row of seats passenger compartment 4G0 W/o storage trays, first row of seats
Seat storage trays, second row of seats passenger compartment 4WA W/o storage trays, second row of seats
Second battery/battery installation 8FA Without second battery
Second generator 8HA Without second alternator or preparation
Second heat exchanger 6AB Second heat exchanger, air outlet first row of seats
Second row of seats 3UF 3-seater, center seat fixed left and right folding
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side interior trim, passenger and load compartment 5DD Comfort side panel trim in passenger compartment
Socket 7B0 Without socket
Sound combination for rotating emergency light 9LA Without rotating emergency lights
Spare wheel mounts 1B1 Standard spare wheel bracket
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RL 6 speakers (passive)
Special editions E0A No special edition
Special labels/plates 0SB Labels/plates in German
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Stacking panel in load compartment 3E0 W/o stacking panel in load compartment
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PG Steering wheel
Step illumination 9N2 Step illumination with on/off control
Sticker (customized or special edition) 0KA Without stickers and badges
Stowage box 3Z0 Without stowage box
Stretchers 5LA Without stretcher
Strip and films all-around 5M0 Without warning strip and films
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Suspension, chassis 1P0 Standard suspension
Tachograph/logbook 9NA Without tachograph
Tail and side gates 5S0 Without tail and side gate(s)
Third row of seats 3VG 2-seater bench seat with fixed separate seat, right
Tires H6W Tires 205/65 R15 C 100T
Tool kit and jack 1S1 Tool kit and jack
Top frame and tarpaulin 5GA Without pickup bodywork/tarpaulin
Trailer hitch 1D6 Trailer hitch
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Tray areas, cab 5FE Tray under dashboard, center
Type approval countries/countries with special requirements B01 Type approval Germany
Underseal 5U0 Standard underseal
Vehicle class differentiation units/platform components 0CN Vehicle class differentiation 7D0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Versions FM2 Comfort variant
Water trap 2M0 Without water trap
Wheel covers 1ND Full wheel covers
Wheelbases 0E2 Long wheelbase
Wheels C7X Alloy wheels 8J x 19 front, with 9.5J x 19 rear
Window regulator 4R1 Power windows
Windows, cab 4CC Cab side window in heat-insulating glass
Windshield glass type 4GF Windshield in heat-insulating glass
PG1
R25
Base engine T7K 5-cylinder diesel engine 2.5 L unit 074.5
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Shogun1985
Proszę o szybkie sprawdzenie: BORA VIN WVWZZZ1JZ2W431581
http://forum.vwgolf.pl/viewtopic.php?f=119&t=462007
CAŁY MK4 2.8 4MOTION NA CZESCI
Tel kont 793-433-821
Bora:
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ2W431581
Model Designation bora tdi variant
Model BO
Date of production 21.11.2001
Model year 2002
Sales type 1J6086
Engine code ASZ
Transmission code ERF
Axle drive 6S
Interior trim code 17
Roof color 7D
Exterior color / Paint Code 7D / B5N
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional warning lights 9TB Additional warning lights (door area)
Air duct, front area VK0 Air duct, standard
Antennas 8L3 Roof antenna
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H0 Without backrest release for front seats
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C0 Without special body measures
Body style K8M Bora station wagon/Jetta station wagon
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1ZE Disc brakes, front (Geomet D)
Brake type, rear 1KT Disc brakes, rear (Geomet D)
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JN Comfort bumpers with chrome-plated strip
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A8 CD changer (front)
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E3 Front center armrest
Center rear seat belts 3C1 Static lap belt, center rear
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M0 Without cup holder
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YR Door pockets with insert mats
Doors 0A2 4 doors
Emission standard 0GE Emission standard EU3
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T2 Warning triangle
Floor coverings 3MH Dilours floor covering w/o scuff guard
Floor mats 0TD Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front license plate bracket 6W1 License plate bracket front (large)
Front stabilizer 0AE Front stabilizer
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel systems 0F9 Cooled fuel system for diesel engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C23 Operating permit, alteration
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8BN Halogen headlight for driving on the right
Headlight washer system 8X1 Headlight washer system
Headrests 5ZE Frame headrests for front seats
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5TX Decorative inserts for special edition
Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
Left exterior mirror 5SL Left exterior mirror: aspherical
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U2 Sliding trunk cover
Luggage compartment floor covering 6SL Tufted trunk floor covering (cut pile)
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 0NA Without nameplate set (without model designation)
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Owner's manuals 0VA Without information kit
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Partition 3CX Net partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P3 Rear floor panel module, type 4
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B8 Body-colored protective side molding with trim stripe
Radiator grille 6KJ Radiator grille with chrome-plated strip
Radios 8AQ Radio "beta" with removable operating panel
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N5 Standard rear axle
Rear cargo area 3GN Variable cargo area concept
Rear headrests 3T0 Frame headrests, rear
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NE Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 0BC Rear stabilizer
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RQ Right exterior mirror: convex
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S2 Black roof rails
Rough-road/sports version 2UA Standard design
Seat adjustment 3L3 Manual height adjustment for front seats
Seat covering N2Z Seat covering for special editions
Seat heater 4A3 Seat heater for front seats separately controlled
Shock absorption, chassis, front G72 Front shock absorption
Side air bag 4X1 Side air bag front
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Speaker installation 8RE 4 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E79 "Special"
Special registration measures 3M0 Without special measures
Steering 1N1 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering wheels 2PX Leather trimmed sports steering wheel
Sticker (customized or special edition) 0KZ Stickers for special editions
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Taillight assemblies 8SA Taillight assemblies, standard design
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tires H6S Tires 195/65 R15 V
Tool kit and jack 1S7 Tool kit and aluminum jack
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0K 6-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Tray 7N0 Without tray on roof liner
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L19 Suspension range 19 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheel covers 1NN Full wheel covers
Wheels C6E Steel wheels 6J x 15 Offset 38
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PJR
PME
PSF
Child seats QA0 Without child seat
Chrome work package QJ1 Chrome work package
Electronic map cooling system QS0 Without electronic map cooling system
Front seats Q1A Standard front seats
Nameplates for sales name QD0 Without lettering for sales name
Service interval prolongation QG1 Service interval prolongation
RBH
Base engine T9J 4-cylinder diesel engine 1.9 L unit 038.K
Control number (no PR-Family) SA0 Model year change calendar week 45
Shock absorption, chassis, rear UB2 Rear shock absorption for sports design
Czy nadal potrzebujesz pomocy w sprawdzeniu tego vinu?Shogun1985 pisze:Proszę o szybkie sprawdzenie: BORA VIN WVWZZZ1JZ2W431581
Jeśli tak zapraszam do aukcji:
http://allegro.pl/sprawdz-oryginalny-pr ... ?source=oo" onclick="window.open(this.href);return false;
dla forumowiczów inne specjalne niższe ceny
Jak jestes zainteresowany to pisz na :
sprawdz.vin@op.pl
pozdrawiam
nie ma dostępnej historii ,samochód jest z Angliitypolo pisze:WVWZZZ6NZXY010955
polo mk3
Z gory dziekuje za pomoc!!
blackberrr
- Fucker
- "KAMELEON" BLACHARSTWO/LAKIERNICTWO
blackberrr,
Potrzebujesz historii serwisowej ?
To zapraszam na PRIV, gg 3119884 lub VIN wysłać smse'm (będzie najszybciej). Nr. w moim podpisie.
Oferuje kompletną historię o samochodzie ! A nie tylko ostatni wpis.
Oczywiście odpłatnie, na życzenie wystawiam rachunek za usługę.
blackberrr pisze:Passat B5fl vin: WVWZZZ3BZ3P055883
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ3BZ3P055883
Model Designation passat saloon
Model PA
Date of production 11.06.2002
Model year 2003
Sales type 3B32F1
Engine code ALT
Transmission code FXR
Axle drive 5S
Interior trim code RW
Roof color A1
Exterior color / Paint Code A1 / 041
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EP Additional stone guard body covers
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Base engine T0F 4-cylinder gasoline engine 2.0 L unit 06B.E (aluminum)
Batteries J1L Battery 280 A (60 Ah)
Body style K8B Notchback
Brake type, front 1ZC Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Bumper 2JB Standard bumpers
CD changer/CD player 7A0 Without CD changer/CD player
Center rear seat belts 3C3 Lap belt with retractor for the center rear seat
Chrome work package QJ0 Without aluminum/chrome work package
Cruise control 8T1 Cruise control system (CCS)
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Cup holder 4M5 Cup holder
Door and side trim panels 3LC Door and side trim panel in foam film and woven fabric
Double-size standard radio/dual-view display 2T0 Without double-sized standard (DIN)
Duty-free tires 1V0 Without duty-free and cost-free tires
Emission standard 0GG Emission standard EU4
Engine specifications MW2 4-cyl. gasoline engine 2.0 L/96 kW 20V with multi-point injection base engine is T0F
Equipment levels A8G Sports comfort equipment
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
Exterior noise suppression measures 2B2 Additional exterior noise suppression
Flame retardent materials 4Q0 No flame retardent materials
Floor coverings 3MQ Ibolours floor covering
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WD Integrated front fog light
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Gearshift boot/cover 6R1 Leatherette gearshift boot
General operating permit, alterations C06 Operating permit, alteration
Hands-free system VX0 Without hands-free system
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heated washer nozzles 9T0 Without heated washer nozzles
Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
Inserts 5MD Decorative aluminum inserts
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder engine
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Luggage compartment floor covering 6SD Tufted trunk floor covering (dimensionally stable)
Manufacturing sequence differentiation 0FG Mosel manufacturing sequence
Moldings 4ZB Bright moldings
Nameplate set 1DB Nameplate set "2.0"
Outdoor temperature gage 9Y1 Outdoor temperature gage
Owner's manuals 0VH Information kit in Dutch
Paint coating FB3 Surface, interior trim, soft-touch paint
Parking light indicator light 8NA Without parking light warning light
Protective side molding 4B1 Protective side molding
Radios 8AA Without radio
Reading light 8S4 Two reading lights front, two rear
Rear cargo area 3GK Without additional lower part for luggage compartment floor
Rear headrests 3Q1 Rear headrests
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Safety certificate 0LA Without special plates/stickers/ safety certificates
Seat covering N0N Woven fabric seat covering
Shock absorption/suspension, chassis 1BE Sports suspension/shock absorption
Side air bag 4X3 Side air bag front with curtain air bag
Side lights 8F2 Side turn signal lights
Ski bag 3X0 Without load-through provision
Smoking/non-smoking package 9JA Non-smoking package
Socket 7B3 12-volt socket(s)
Speaker installation 8RM 8 speakers (passive)
Special labels/plates 0SE Labels/plates in Dutch
Tires H6U Tires 205/55 R16 91W
Transmission shafts 1WD Transmission shaft for tripod joints
Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
Type approval countries/countries with special requirements B31 Type approval the Netherlands
Vehicle class differentiation units/platform components 0DE Installation differentiation for build status of vehicle class B5 (VW Passat)
Weight category front axle 0JE Weight category front axle weight range 5
Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
Wheel covers 1NA Without wheel covers
Wheels C4Q Alloy wheels 8J x 18
Window regulator 4R3 Power windows with comfort operation
Windshield glass type 4GH Windshield in heat-insulating glass with sunshield
Windshield wiper intermittent control 8N3 Windshield wiper intermittent control with rain sensor
P15
PJ2
Front seats Q4H Comfort sports seats, front Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Proszę o sprawdzenie WVWZZZ1JZ3D009691
Golf IV
Z góry dziękuje!!
Golf IV
Z góry dziękuje!!
- Fucker
hmmm.. co to moze oznaczac?? bylem w aso i tam powiedzieli ze volkswagen zastrzega wszelkie informacje ;/ dowiedzialem sie tylko dokladna date produkcji i z jakiego kraju auto pochodzi.
