Chcesz kupić, bądź sprowadzić auto..nie wiesz, które wybrać? Napisz o tym tutaj...
VIN
Post
autor: VIN » ndz sty 23, 2011 21:17
kubik78 pisze:Proszę o sprawdzenie
WVWZZZ1HZWB066232
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1HZWB066232
Model Designation golf tdi
Model GO
Date of production 08.12.1997
Model year 1998
Sales type 1H1024
Engine code ALE
Transmission code ASD
Axle drive 5S
Interior trim code 71
Roof color B4
Exterior color / Paint Code B4 / B9A
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B0 Without additional child seat anchor
Additional tires (winter tires) 2WA Without additional tires
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TA Without additional warning lights
Air bag 4UE Air bag for driver and front seat passenger
Antennas 8L1 Bright rod antenna
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Ashtray light 8PB Ashtray light
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Backrest release 3H0 Without backrest release for front seats
Batteries J0N Battery 330 A (61 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U0 Without brake pad wear indicator
Brake type, front 1LY Disc brakes, front
Brake type, rear 1KB Drum brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
Bumper 2JG Body-colored bumpers
CD changer/CD player 7A0 Without CD changer/CD player
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Catalytic converter control 8KA W/o catalytic converter warning light
Cd enhancing underbody panel 2D0 Without cd enhancing underbody panel
Center high-mounted stop light 8R1 Center high-mounted stop light
Center rear seat belts 3C1 Static lap belt, center rear
Chassis 2E0 Base chassis
Climatic zones 0Y1 Standard climatic zones
Clutch actuation 1K2 Hydraulic clutch actuation
Component part sets with country-specific design requirements B0X Component parts set, complying with vehicle type for Germany, various parts
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Cruise control 8T0 Without cruise control system (CCS)
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Dashboard 4N1 Padded dashboard
Door and lid locking system 4F0 Mechanical locking system
Door and side pockets, rear 4YB Stowage box rear (door and side panel)
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YH Door pockets, front
Doors 0A2 4 doors
Drive layout 1X0 Front wheel drive
Engine guard 1SA Without additional engine guard
Engine specifications M9Z 4-cyl. turbo diesel engine 1.9 L/66 kW TDI with central EGR extraction base engine is T2F
Equipment levels A8C Comfort equipment
Exterior noise suppression measures 2B5 Additional exterior noise suppression
Flame retardent materials 4Q0 No flame retardent materials
Floor coverings 3MQ Ibolours floor covering
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WH Front fog lamp and cornering lamp
Front spoiler 5L1 Front spoiler
Front stabilizer 0AJ Front stabilizer
Front turn signal lights 6Z2 White turn signal lights
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel tank treatment 2LA Fuel tank without special material treatment
Fuel tank vent line 1TB Fuel tank vent line with gravity valve and PVC breather hose
Gearshift boot/cover 6R3 Rubber gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C00 Operating permit, initial registration
Generators 8GL Alternator 120 A
Glove compartment 4Z2 Lockable glove compartment door
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8BB Halogen headlight for driving on the right
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AA Manually controlled heating system
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Interference suppression 8E0 Without interference suppression
Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
Key for locking system 8QA Key without LED
Label for brake-proportioning values 0Q0 Without label for brake-proportioning values
Lashing rings/rails for load restraint 6B0 Without lashing rings for load restraint
Left exterior mirror 3BS Left exterior mirror: aspherical, electrically adjustable and heated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lighting 9E1 Luggage compartment lighting
Luggage compartment lining 5A2 Comfort trunk lining
Manufacturing sequence differentiation 0FC Brussels manufacturing sequence
Molding roof liner 6NA Unsplit molding roof liner
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 2QY Nameplate set "TDI" in base trim
Navigation device 7Q0 Without navigation device
Night vision system 9R0 Without night vision system
Outer rear seat belts 3ZE 3-point seat belts, outer rear with height adjustment and ECE label
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Partition 3CA Without partition
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KA Radiator grille
Radios 8AS Radio "alpha Europa"
Reading light 8S1 Reading light front
Rear axle 0N2 Heavy-duty rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q0 Without rear headrests
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seats 3NB Rear seat bench/backrest, completely folding
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BA Without rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 3AF Right exterior mirror: convex, electrically adjustable and heated
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Seat adjustment 3L0 Without special seat adjustment
Seat belt check 9P0 Without seat belt reminder
Seat covering N2Z Seat covering for special editions
Seat heater 4A0 Without seat heater
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side air bag 4X0 Without side air bag
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side assist/lane departure warning 7Y0 Without lane change assistant
Side lights 8F6 Dark colored side turn signal lights
Spare wheel/breakdown set 1G6 Space-saving spare wheel
Speaker installation 8RD 2 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E1A "Arte"
Special labels/plates 0SB Labels/plates in German
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 1N1 Power steering
Steering column systems 2C0 Standard steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PY Steering wheel for air bag system (RoW) (lightweight design)
Sticker (customized or special edition) 0KZ Stickers for special editions
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Telephone/telematics 9W0 W/o car phone preparation/installation
Tires H4V Tires 175/70 R14 88H
Trailer hitch 1D0 Without trailer hitch
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Trunk sill protection 2P1 Plastic trunk sill protection
Type approval countries/countries with special requirements B01 Type approval Germany
Vehicle class differentiation units/platform components 0DG Installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
Vehicle specifications F0A No special purpose vehicle, standard equipment
Wheel covers 1NC Full wheel covers
Wheels C8E Steel wheels 6J x 14
Window regulator 4R5 Power windows with comfort operation and circuit breaker, mechanical window regulators rear
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control 8N2 Windshield wiper intermittent control infinitely variable
PN1
Front seats Q1A Standard front seats
RAK
Base engine T2F 4-cylinder diesel engine 1.9 L unit 028.C
Instrument inserts U1L Instrument insert w/ km/h speedometer, clock, tachometer and special color trim
Tire suppliers V0A Tires w/o specification of tire brand
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
djarek4
Post
autor: djarek4 » wt sty 25, 2011 11:58
Witam czy można sprawdzić numer vin WVWZZZ3BZVE040284 z góry dzieki Arek
VIN
Post
autor: VIN » wt sty 25, 2011 15:24
djarek4 pisze:Witam czy można sprawdzić numer vin WVWZZZ3BZVE040284 z góry dzieki Arek
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ3BZVE040284
Model Designation passat saloon
Model PA
Date of production 17.12.1996
Model year 1997
Sales type 3B2355
Engine code AFN
Transmission code DHF
Axle drive 5S
Interior trim code HX
Roof color J8
Exterior color / Paint Code J8 / N5Y
Additional body covers, side 6EP Additional stone guard body covers
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2XB Winter tires 195/65 R 15 91H with steel wheel 6J x 15, offset 45 (5-hole) without full wheel cover (C0V)
Batteries J0R Battery 380 A (80 Ah)
Body style K8B Notchback
Brake type, front 1LB Disc brakes, front
Bumper 2JB Standard bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
Carrier frequency for radio remote control 5D0 Without carrier frequency
Center armrest 6E3 Front center armrest
Center rear seat belts 3C3 Lap belt with retractor for the center rear seat
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Cup holder 4M6 Cup holder
Dashboard illumination 7V0 Standard dashboard illumination
Door and lid locking system 4F1 Central locking system
Door and side trim panels 3LC Door and side trim panel in foam film and woven fabric
Duty-free tires 1V0 Without duty-free and cost-free tires
Engine cooling system 8Z5 Not hot country
Engine specifications M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDI with MVEG 2 base engine is T1R
Equipment levels A8S Standard equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B1 Additional exterior noise suppression
First aid kit / warning triangle 1T2 Warning triangle
Front fog light/additional headlight 8WD Integrated front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C01 Operating permit, alteration
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8JM Twin headlight for driving on the right, with integrated high beam
Heated door lock cylinder 9X0 Without heated door lock cylinder
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AB Manually controlled air conditioning
Inserts 5MD Decorative aluminum inserts
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder engine
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Label for radio remote control 7CA Without label for radio remote control
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SD Left vanity mirror, illuminated
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment floor covering 6SD Tufted trunk floor covering (dimensionally stable)
Luggage net/pocket on backrest(s) 4U1 Luggage nets/pockets on backrests
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Malfunction display 9HA Without additional malfunction display
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Moldings 4ZE Black moldings
Nameplate set 2VP Nameplate set "TDI" "I"
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Parking light indicator light 8NA Without parking light warning light
Protective side molding 4B1 Protective side molding
Radios 8AC Radio "beta"
Reading light 8S4 Two reading lights front, two rear
Rear cargo area 3GK Without additional lower part for luggage compartment floor
Rear headrests 3Q1 Rear headrests
Rear seat catch 6QB Locking rear seat catch
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Safety certificate 0LA Without special plates/stickers/ safety certificates
Seat adjustment 3L3 Manual height adjustment for front seats
Seat covering N0N Woven fabric seat covering
Seat heater 4A3 Seat heater for front seats separately controlled
Side air bag 4X1 Side air bag front
Side lights 8F2 Side turn signal lights
Ski bag 3X0 Without load-through provision
Socket 7B0 Without socket
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RE 4 speakers (passive)
Special editions E0A No special edition
Steering wheels 2PX Leather trimmed sports steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Taillight assemblies 8SA Taillight assemblies, standard design
Tires H6S Tires 195/65 R15 V
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Vehicle class differentiation units/platform components 0DE Installation differentiation for build status of vehicle class B5 (VW Passat)
Weight category front axle 0JZ Without determination of weight category for front axle
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheels C0V Steel wheels 6J x 15
Window regulator 4R3 Power windows with comfort operation
PH1
Front seats Q4H Comfort sports seats, front
RBB
Base engine T1R 4-cylinder diesel engine 1.9 L unit 028.R
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
aresek
Post
autor: aresek » wt sty 25, 2011 18:18
Witam, proszę o sprawdzenie vw golf po nr vin. Bardzo zależy mi na informacji odnośnie wymiany rozrzadu. Naprawa była wykonywana w ASo vw. wvwzzz1jzyw226426 Z góry bardzo dziękuje!
Kamil83
Post
autor: Kamil83 » śr sty 26, 2011 01:49
Hejka, właśnie zakupiłem swojego pierwszego VW i bardzo bym prosił o sprawdzenie po nr VIN (WVWZZZ1JZWB035362) z jakim kolorem wyjechał z fabryki i z jakim wyposażeniem. Z góry dziękuję
Fajnie być częścią stada VW
Golf IV 1.6sr AKL 98r. 74kw + sekwencyjna instalacja lpg BRC
VIN
Post
autor: VIN » śr sty 26, 2011 10:45
Kamil83 pisze:Hejka, właśnie zakupiłem swojego pierwszego VW i bardzo bym prosił o sprawdzenie po nr VIN (WVWZZZ1JZWB035362) z jakim kolorem wyjechał z fabryki i z jakim wyposażeniem. Z góry dziękuję
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZWB035362
Model Designation golf 1.6
Model GOLF
Date of production 23.03.1998
Model year 1998
Sales type 1J12J4
Engine code AKL
Transmission code DLP
Axle drive 5S
Interior trim code KM
Roof color G9
Exterior color / Paint Code G9 / C3K
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Additional warning lights 9TB Additional warning lights (door area)
Antennas 8L3 Roof antenna
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Auxiliary heating 9M0 Without auxiliary/parking heater
Batteries J1L Battery 280 A (60 Ah)
Brake type, front 1LQ Front disc brakes with integrated adapter
Brake type, rear 1KK Disc brakes, rear
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AR Door and side trim panel in foam film and circular-knit
Door pockets, front 3YR Door pockets with insert mats
Doors 0A2 4 doors
Engine compartment lighting 9L0 Without engine compartment lighting
Engine specifications ME8 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 3D base engine is T6H
Floor mats 0TQ Front and rear floor mats (polypropylene)
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front stabilizer 0AM Front stabilizer
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R1 Leatherette gearshift boot
General operating permit, alterations C03 Operating permit, alteration
Generators 8GD Alternator 90A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Headlight 8JS Twin headlight for driving on the right with clear lens
Headlight washer system 8X1 Headlight washer system
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5MA Decorative inserts
Key for locking system 8QE Key for locking system with remote control
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Molding roof liner 6NH Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 0QE Nameplate set "1.6"
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Paint preservative/transit coating 5K1 Paint preservative (wax)
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Radiator grille 6KG Radiator grille
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N1 Standard rear axle
Rear seat catch 6QA Rear seat catch
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 0BC Rear stabilizer
Seat covering N0U Cut pile seat covering
Shock absorption, chassis, front 1GA Front shock absorption, basic design 1
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering wheels 1MP Steering wheel for air bag system
Throttle actuation 0L0 Mechanical throttle actuation
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Tires H1T Tires 175/80 R14 88H
Tool kit and jack 1S7 Tool kit and aluminum jack
Transmission types/gearshift mechanisms 0G3 Gearshift linkage
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Washer fluid level indicator 8W1 Washer fluid level indicator
Wheels C6D Steel wheels 6J x 14 Offset 38
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PH2
PT1
PTB
Base engine T6H 4-cylinder gasoline engine 1.6 L unit 06A.F (aluminum )
Front seats Q2J Comfort front seats
RBB
Control number (no PR-Family) S3K Pool campaign
Control number (no PR-Family) S4Q Plant employee leasing for Poland
Weight category front axle U22 Suspension range 121
djarek4
Post
autor: djarek4 » śr sty 26, 2011 18:39
Proszę o sprawdzenie numeru Vin WVWZZZ3Bzvp113563 z góry dziękuje i pozdrawiam Arek
VIN
Post
autor: VIN » śr sty 26, 2011 19:54
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ3BZVP113563
Model PA
Date of production 12.04.1997
Model year 1997
Sales type 3B2335
Engine code AHU
Transmission code DHL
Axle drive 5S
Interior trim code GP
Roof color G2
Exterior color / Paint Code G2 / Y3D
Base engine T0T 4-cylinder diesel engine 1.9 L unit 028.M
Brake type, front 1LZ Front disc brakes, standard ventilation
Component part sets with country-specific design requirements B0B Component parts set, complying with vehicle type for Austria, various parts
Door and side trim panels 3LD Door and side trim panel
Engine specifications M0T 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection base engine is T0T
Front fog light/additional headlight 8WA Without front fog light
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C04 Operating permit, alteration
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Manufacturing sequence differentiation 0FG Mosel manufacturing sequence
Nameplate set 2QK Nameplate set "TDI"
Outdoor temperature gage 9Y1 Outdoor temperature gage
Radios 8AA Without radio
Speaker installation 8RM 8 speakers (passive)
Steering wheels 2PQ Steering wheel for air bag system
Tires H6R Tires 195/65 R15 T
Type approval countries/countries with special requirements B12 Type approval Austria
konrad79
Post
autor: konrad79 » czw sty 27, 2011 15:57
Prosiłbym o sprawdzenie takiego vinu ,kolega chcę kupić ten samochód i jesteśmy ciekawi czy ma moze jakąś historię WVWZZZ1JZ1D650968
Vincent27
Post
autor: Vincent27 » czw sty 27, 2011 19:19
Prosze o sprawdzenie tego num. Z góry dzięki
WVWZZZ1HZSW338325
Lead
Post
autor: Lead » sob sty 29, 2011 16:43
Hej witam!
Słuchajcie mam okazję kupić ładnego MK4 z pakietem generation. Mam VIN, jeśli dało by się sprawdzić co i jak to byłbym BARDZO wdzięczny.
Pozdrawiam i z góry SERDECZNIE DZIĘKUJĘ.
WVWZZZ1JZYW506825
zanus
Post
autor: zanus » sob sty 29, 2011 23:40
Witam, proszę o rozkodowanie passata 3bg vin WVWZZZ3BZ1P279948
Jlz
Post
autor: Jlz » ndz sty 30, 2011 15:11
Proszę o sprawdzenie VIN
WVWZZZ1JZ3W183142
aerandin
Post
autor: aerandin » ndz sty 30, 2011 19:24
Hej.
Czy możecie dla mnie sprawdzić ten VIN:
WVWZZZ1HZTW044036
Chcę się upewnić czy jest to zwykły Golf, czy Golf GTI
A dodatkowe informacje jak najbardziej mile widziane.
Użytkownicy przeglądający to forum: Google [Bot] i 44 gości
