Nie daj się oszukać, sprawdź VIN i historię
Nie daj się oszukać, sprawdź VIN!
a odnosnie servisowania coś sie dowiemy i przebiegu?? sorry ale jestem zielony z tego
Kolego VIN prosba. Dalo by rade odkodowac numer:
WVWZZZ1JZ1D173170
Dzieki i pozdrawiam
WVWZZZ1JZ1D173170
Dzieki i pozdrawiam
"Twoj samochód jest wystarczająco szybki wtedy, gdy stojąc rankiem przed nim boisz się go otworzyć" - Walter Röhl
						Re: Nie daj się oszukać, sprawdź VIN!
olsen72 pisze:Witam
WVWZZZ1JZ1D173170
Dzieki i pozdrawiam
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ1D173170
Model Designation	golf v6 4motion
Model	GOLF
Date of production	29.07.2000
Model year	2001
Sales type	1J13W7
Engine code	AUE
Transmission code	DRP
Axle drive	6S
Interior trim code	VV
Roof color	1D
Exterior color / Paint Code	1D / W5Z
Activated carbon canister 	1E1 	Activated carbon canister
Additional body covers, side 	6EJ 	Additional body cover on sill without wheel arch
Additional child seat anchors 	3B0 	Without additional child seat anchor
Additional dust seals 	6U0 	Without additional seals outside
Additional tires (winter tires) 	2WA 	Without additional tires
Additional tunnel cover 	4J1 	Floor tray, extension center console
Additional warning lights 	9TB 	Additional warning lights (door area)
Air bag 	4UE 	Air bag for driver and front seat passenger
Antennas 	8L3 	Roof antenna
Anti-theft protection system 	7AH 	Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
Antifreeze 	1C1 	Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 	9FA 	Without automatic transmission indicator light
Auxiliary heating 	9M0 	Without auxiliary/parking heater
Backrest release 	3H8 	Backrest release for front seats with "Easy Entry" and memory function
Batteries 	J1L 	Battery 280 A (60 Ah)
Body measures 	5C3 	Body measures for increased safety requirements
Body style 	K8G 	Hatchback
Brackets 	3P1 	Bracket for first aid kit and warning triangle
Brake pad wear indicator 	9U1 	Brake pad wear indicator
Brake type, front 	1LJ 	Disc brakes, front
Brake type, rear 	2EE 	Disc brakes, rear
Braking systems 	1AT 	Electronic stabilization program (ESP)
Breakaway interior mirror 	4L2 	Dipping breakaway interior rear view mirror
Bumper 	2JC 	Comfort bumpers
CD ROM/DVD/SD card 	7QA 	Without CD/DVD for navigation
CD changer/CD player 	7A2 	CD changer
Carrier frequency for radio remote control 	5D1 	Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 	4W0 	Without cassette and CD storage unit
Cd enhancing underbody panel 	2D1 	Complete cd enhancing underbody panel
Center armrest 	6E3 	Front center armrest
Center rear seat belts 	3C7 	3-point seat belt for center rear seat
Component part sets with country-specific design requirements 	B0N 	Component parts set, complying with vehicle type for Great Britain, various parts
Components with special surface appearance 	6FF 	Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 	4LA 	Without controls
Cruise control 	8T2 	Cruise control system (CCS) electronic
Cup holder 	4M6 	Cup holder
Door and lid locking system 	4K3 	Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 	3LJ 	Door and side trim panel in foam film, insert in leatherette
Door pockets, front 	3YR 	Door pockets with insert mats
Doors 	0A1 	2 doors
Drive layout 	1X1 	Four wheel drive
Electronic map cooling system 	QS0 	Without electronic map cooling system
Emission standard 	0GG 	Emission standard EU4
Engine compartment lighting 	9L0 	Without engine compartment lighting
Engine cooling system 	8Z5 	Not hot country
Engine guard 	1SA 	Without additional engine guard
Engine specifications 	D6B 	6-cyl. gasoline eng. 2.8 L/150 kW 24V VR6 base engine is T9T
Equipment levels 	A8F 	Sports equipment
Exterior mirror setting 	6XD 	Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 	2B8 	Additional exterior noise suppression
Fire extinguisher 	6A0 	Without fire extinguisher
First aid kit / warning triangle 	1T0 	Without first aid kit and warning triangle
Floor coverings 	3MF 	Dilours floor covering with scuff guard
Floor mats 	0TD 	Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 	2V5 	Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 	8WD 	Integrated front fog light
Front license plate bracket 	6W1 	License plate bracket front (large)
Front stabilizer 	0AS 	Front stabilizer
Fuel filler cap/door, locking option 	2W0 	Fuel filler cap
Fuel quantity for initial filling 	1Z0 	Initial standard fuel filling
Fuel systems 	0F2 	Fuel system for carburetor gasoline engine
Fuel tank treatment 	2LB 	Fuel tank with special material treatment
Gearshift boot/cover 	6R2 	Leather gearshift boot
Gearshift knob/handle 	6Q3 	Wooden gearshift knob/handle
General operating permit, alterations 	C16 	Operating permit, alteration
Generators 	8GL 	Alternator 120 A
Grab handles at roof frame 	5N6 	Folding grab handles at roof frame soft fold-away
Hand brake lever handle 	6PC 	Leather hand brake lever handle
Headlight 	8JU 	Twin headlight for driving on the left with clear lens
Headlight activation 	8K0 	Without special headlight activation
Headlight washer system 	8X1 	Headlight washer system
Headlight-range adjustment 	8Q1 	Headlight-range adjustment
Headrests 	3J7 	Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 	7E2 	Heated crankcase ventilation system
Heated washer nozzles 	9T1 	Heated washer nozzles, front
Heating and air conditioning system 	9AK 	Climatronic with impact pressure control free of cfc
Horns 	8Y1 	Two-tone horn
Identification plates 	1EX 	Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 	0RA 	Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 	2G7 	Filler neck module 1 with insert
Inserts 	5MG 	Decorative inserts, burr-walnut
Installation differentiation for vehicle components 	0EN 	Installation differentiation for transmission MQ 350 vehicle components
Left exterior mirror 	5SJ 	Left exterior mirror: convex
Left vanity mirror 	4SD 	Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 	4E0 	Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 	1PC 	Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover 	3U1 	Foldable trunk cover
Luggage compartment floor covering 	6SM 	Needle-punched trunk floor covering (Dilours)
Luggage compartment lining 	5A7 	Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 	4U5 	Luggage pockets on backrest
Lumbar support 	7P4 	Manually adjustable lumbar support in front seats
Manufacturing sequence differentiation 	0FK 	Bratislava manufacturing sequence
Mass damper for steering wheels 	1Q0 	Without mass damper for steering wheel
Multi-function display/trip computer 	9Q1 	Multi-function display/on-board computer
Nameplate set 	0PV 	Nameplate set "V6 4MOTION"
Navigation device 	7Q0 	Without navigation device
Outdoor temperature gage 	9Y0 	Without outdoor temperature gage
Outer rear seat belts 	3ZM 	3-point seat belts, outer rear
Paint coating 	FB0 	Standard paint coating
Paint preservative/transit coating 	5K0 	Without surface protection, with additional transit coating
Park distance control 	7X0 	Without park distance control
Partition 	3CA 	Without partition
Platform group class 	7PA 	Platform group class 1
Platform module floor pan, rear 	4P0 	Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 	9F0 	Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 	9D0 	Without preparation for two-way radio installation
Proportioning valve 	1H0 	Without proportioning valve
Protective side molding 	4B2 	Body-colored protective side molding
Radiator grille 	6KG 	Radiator grille
Radios 	8AD 	Radio "gamma"
Reading light 	8S2 	One reading light front, two reading lights rear
Rear axle 	0N1 	Standard rear axle
Rear cargo area 	3GA 	Without cargo area
Rear fog light 	8TD 	Rear fog light for driving on the left
Rear headrests 	3T3 	3 rear headrests height-adjustable
Rear license plate bracket 	6P1 	License plate bracket rear (ECE)
Rear seat catch 	6QA 	Rear seat catch
Rear seats 	3NC 	Rear seat bench/backrest, split folding
Rear stabilizer 	0BT 	Rear stabilizer
Rear window wiper and washer system 	8M1 	Rear window wiper and washer system with intermittent control
Restraint systems, front 	3QT 	3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 	5RV 	Right exterior mirror: aspherical
Right vanity mirror 	4TD 	Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 	3Y0 	Without roll-up sun screen
Roof insert/convertible top 	3FA 	Without roof insert (standard roof)
Roof rails/roof load rack 	3S0 	Without roof rails/roof load rack
Rough-road/sports version 	2UA 	Standard design
Seat adjustment 	3L3 	Manual height adjustment for front seats
Seat belt check 	9P0 	Without seat belt reminder
Seat covering 	N2F 	Part leather seat coverings casual fold
Seat heater 	4A3 	Seat heater for front seats separately controlled
Shock absorption, chassis, front 	G88 	Front sports shock absorption
Shock absorption, chassis, rear 	1JU 	Rear shock absorption, basic design four wheel drive
Side air bag 	4X1 	Side air bag front
Side and rear windows 	4KC 	Side and rear windows in heat-insulating glass
Side lights 	7R3 	Side turn signal lights (white)
Smoking/non-smoking package 	9JB 	Smoking package, ashtray front and rear
Socket 	7B2 	12-volt socket in luggage boot
Spare wheel/breakdown set 	1G9 	Space-saving spare wheel for temporary use, radial tire (5-hole)
Speaker installation 	8RM 	8 speakers (passive)
Special alarm systems 	9A0 	Without taxi alarm system
Special color trim 	0UA 	Without special color trim
Special editions 	E0A 	No special edition
Special labels/plates 	0SC 	Labels/plates in English
Special registration measures 	3M0 	Without special measures
Speedometer cable and seal 	8CC 	Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 	7L0 	Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 	QZ2 	Power steering for special demands (additional damping valves)
Steering column systems 	2C5 	Axial and vertical adjustable steering column
Steering system arrangement 	L0R 	Right-hand drive vehicle
Steering wheels 	2PX 	Leather trimmed sports steering wheel
Sticker (customized or special edition) 	0KA 	Without stickers and badges
Supertone system and tone sequence control 	9J0 	Without supertone system and tone sequence control
TV reception/digital radio reception 	QV0 	W/o TV reception/digital radio reception
Taillight assemblies 	8SB 	Taillight assembly w/ dark colored lens
Telephone/telematics 	9W0 	W/o car phone preparation/installation
Throttle actuation 	0L2 	Electric throttle actuation
Tires 	H6U 	Tires 205/55 R16 91W
Tool kit and jack 	1S7 	Tool kit and aluminum jack
Trailer hitch 	1D0 	Without trailer hitch
Transmission specifications 	G0L 	6-speed manual transmission for four-wheel drive vehicle
Transmission types/gearshift mechanisms 	0G4 	Cable gearshift
Tray 	7N0 	Without tray on roof liner
Trunk sill protection 	2P0 	Without trunk sill protection
Type approval countries/countries with special requirements 	B09 	Type approval Great Britain and Northern Ireland
Vehicle class differentiation units/platform components 	0CE 	Vehicle class differentiation 1J0
Vehicle specifications 	F0A 	No special purpose vehicle, standard equipment
Vehicle type 	AZ0 	Vehicle with standard production scope
Washer fluid level indicator 	8W1 	Washer fluid level indicator
Weight category front axle 	L08 	Suspension range 08 installation control only, no requirement forecast
Weight category rear axle 	0YZ 	Without determination of weight category for rear axle
Wheel covers 	1NL 	Covers for alloy wheels
Wheels 	CF5 	Alloy wheels 6.5J x 16
Window regulator 	4R4 	Power windows with comfort operation and circuit breaker
Windshield glass type 	4GF 	Windshield in heat-insulating glass
Windshield wiper intermittent control 	8N4 	Windshield wiper intermittent control with potentiometer (four speeds)
 	P00
 	PH6
Child seats 	QA0 	Without child seat
Chrome work package 	QJ0 	Without aluminum/chrome work package
Front seats 	Q2Q 	RECARO sports seats, front
Nameplates for sales name 	QD1 	Nameplates for sales name
Service interval prolongation 	QG1 	Service interval prolongation
 	RCA
Base engine 	T9T 	6-cylinder gasoline engine 2.8 L unit 022.A
Instrument inserts 	U0L 	Instrument insert with tachometer clock and mph speedometer
Remote-controlled garage door opener 	VC0 	W/o remote-controlled garage door opener
Tire suppliers 	V0G 	MICHELIN tires Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
				Sieniek0916
Mam prośbę o dane o numerze VIN:
WVGZZZ1TZ4W082890
z góry dziekuję
WVGZZZ1TZ4W082890
z góry dziekuję
Sieniek0916 pisze:Witam
WVGZZZ1TZ4W082890
z góry dziekuję
Kod: Zaznacz cały
Vehicle Identification No.	WVGZZZ1TZ4W082890
Model Designation	touran 2.0
Model	TOU
Date of production	26.11.2003
Model year	2004
Sales type	1T1T31
Engine code	AZV
Transmission code	GNE
Axle drive	6S
Interior trim code	FC
Roof color	8E
Exterior color / Paint Code	8E / A7W
Activated carbon canister 	1E0 	Without activated charcoal canister
Additional body covers, side 	6EA 	Without additional side body covers (stone guard)
Air bag 	4UF 	Driver's and front passenger air bag with front passenger air bag deactivation
Air duct, front area 	VK0 	Air duct, standard
Antennas 	8ZH 	Antenna for AM/FM reception, "diversity"
Anti-theft protection system 	7AA 	Electronic vehicle immobilization device
Auxiliary heating 	9M5 	Auxiliary heater
Backrest release 	3H0 	Without backrest release for front seats
Base engine 	T9G 	4-cylinder diesel engine 2.0 L unit 03G.A
Batteries 	J0L 	Battery 340 A (70 Ah)
Body style 	K8P 	MPV
Brake type, front 	1ZE 	Disc brakes, front (Geomet D)
Brake type, rear 	1KF 	Disc brakes, rear
CD changer/CD player 	7A0 	Without CD changer/CD player
Center armrest 	6E0 	Without center armrest front
Component part sets with country-specific design requirements 	B0A 	Component parts set without country-specific design requirement
Door and side trim panels 	4AF 	Door and side trim panel in foam film and woven fabric
Drawers under front seats 	QN3 	Drawers under front seats
Drive layout 	1X0 	Front wheel drive
Engine specifications 	MS9 	4-cyl. turbo diesel engine 2.0 L/100 kW 16V (TDI) with pump-jet injection system Base engine is T9G/TB3/TQ0/TN0
Equipment levels 	A8G 	Sports comfort equipment
Exterior mirror setting 	6XN 	Exterior mirrors: electrically adjustable, separately heated
First aid kit / warning triangle 	1T2 	Warning triangle
Floor mats 	0TA 	Without floor mats
Front seat, left 	3TF 	Comfort seat, front left
Front seat, right 	3SF 	Comfort seat, front right
Front stabilizer 	0AF 	Front stabilizer
Fuel systems 	0F9 	Cooled fuel system for diesel engine
Gearshift boot/cover 	6R1 	Leatherette gearshift boot
Gearshift knob/handle 	6Q1 	Plastic gearshift knob/handle
General operating permit, alterations 	C03 	Operating permit, alteration
Generators 	8GU 	Alternator 140 A
Glove compartment 	4Z1 	Standard glove compartment
Hand brake lever handle 	6PA 	Plastic hand brake lever handle
Headlight 	8BG 	Twin-headlight for driving on the right, with integrated high beam
Headlight washer system 	8X0 	Without headlight washer system
Heat accumulator system/additional heater 	7E0 	W/o heat accumulator/auxiliary heating
Heated washer nozzles 	9T0 	Without heated washer nozzles
Hinged quarter window 	4MA 	Without rear hinged quarter window
Horns 	8Y0 	Single-tone horn
Insert for the filling up of unleaded fuel/fuel type 	2G5 	Filler neck module 1 without insert
Inserts 	5MA 	Decorative inserts
Instrument inserts 	U5A 	Instrument insert, km/h speedometer
Interference suppression 	8E2 	Local interference suppression for FM/AM radio reception
Left exterior mirror 	5SL 	Left exterior mirror: aspherical
Lock operation for tailgate/trunk lid 	4E2 	Tailgate/trunk lid release from inside (electrically)
Lockable wheel bolts 	1PA 	Standard wheel bolts
Luggage compartment cover 	3U7 	Luggage compartment cover
Nameplate set 	0NB 	Nameplate set in base trim
Outdoor temperature gage 	9Y1 	Outdoor temperature gage
Outer rear seat belts 	3ZG 	3-point seat belts, outer rear with height adjustment
Owner's manuals 	0VB 	Information kit in French
Paint preservative/transit coating 	5K5 	Transit coating film with additional transport protection measures
Pane type (except windshield) 	QL3 	Heat-insulating glass (green)
Radiator grille 	6KJ 	Radiator grille with chrome-plated strip
Radios 	8YL 	Radio with CD player
Rear axle 	0N4 	4-link rear suspension
Rear fog light 	8TC 	Rear fog light for driving on the right
Rear seats 	5KP 	3 separate seats (first row of seats)
Refrigerator 	1W8 	Without refrigerator
Right exterior mirror 	5RQ 	Right exterior mirror: convex
Roof rails/roof load rack 	3S2 	Black roof rails
Safety headrest system 	3K1 	Safety headrest system
Seat belt check 	9P1 	Seat belt reminder, electric contact in buckle
Seat covering 	N0Y 	Seat coverings in flat woven fabric
Seat heater 	4A0 	Without seat heater
Shock absorption, chassis, front 	G26 	Front shock absorption
Shock absorption, chassis, rear 	1JA 	Rear shock absorption, basic design 1
Side air bag 	4X3 	Side air bag front with curtain air bag
Spare wheel/breakdown set 	1G8 	Breakdown set
Speaker installation 	8RE 	4 speakers (passive)
Special labels/plates 	0SA 	Without special labels/plates
Steering 	1N3 	Speed-related variable steering assist (Servotronic)
Steering system arrangement 	L0L 	Left-hand drive vehicle
Steering wheels 	2PQ 	Steering wheel for air bag system
Taillight assemblies 	8SA 	Taillight assemblies, standard design
Tire pressure warning light 	7K0 	Without tire pressure warning light
Tire suppliers 	V0A 	Tires w/o specification of tire brand
Tires 	HH7 	Tires 205/55 R16 91V
Transmission specifications 	G0K 	6-speed manual transmission
Type approval countries/countries with special requirements 	BA1 	Country group Central Europe F, B, NL, L, CH, A
Vehicle class differentiation units/platform components 	1CZ 	Vehicle class differentiation 1T0
Washer fluid level indicator 	8W0 	Without washer fluid level indicator
Weight category front axle 	L24 	Suspension range 24 installation control only, no requirement forecast
Weight category rear axle 	0YA 	Weight range 1 installation control only, no requirement forecast
Wheel covers 	1NV 	Full wheel covers
Wheels 	CM1 	Steel wheels 6.5J x 16
Windshield glass type 	4GQ 	Windshield in heat-insulating glass
Windshield wiper arms/blades 	9PA 	Standard windshield wiper arms/blades
 	PH2
Child seats 	QA0 	Without child seat Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam serdecznie.
Czy moge prosic o sprawdzenie tego VIN
WVWZZZ1JZ3W183142
z gory dziekuje
WVWZZZ1JZ3W183142
z gory dziekuje
olivier85 pisze:Witam serdecznie.
WVWZZZ1JZ3W183142
z gory dziekuje
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ3W183142
Model Designation	golf tdi
Model	GOLF
Date of production	16.08.2002
Model year	2003
Sales type	1J1086
Engine code	ASZ
Transmission code	ERF
Axle drive	6S
Interior trim code	AM
Roof color	Z4
Exterior color / Paint Code	Z4 / C9Z
Base engine 	T9J 	4-cylinder diesel engine 1.9 L unit 038.K
Body measures 	5C0 	Without special body measures
Brake type, rear 	1KS 	Disc brakes, rear (Geomet D)
Braking systems 	1AJ 	Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
Bumper 	2JB 	Standard bumpers
Carrier frequency for radio remote control 	5D0 	Without carrier frequency
Center rear seat belts 	3C1 	Static lap belt, center rear
Components with special surface appearance 	6FE 	Body-colored exterior mirror housings and tailgate handle
Cruise control 	8T0 	Without cruise control system (CCS)
Cup holder 	4M5 	Cup holder
Door and lid locking system 	4F1 	Central locking system
Door pockets, front 	3YQ 	Door pockets without insert mats
Doors 	0A2 	4 doors
Emission standard 	0GE 	Emission standard EU3
Engine specifications 	D3E 	4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels 	A8C 	Comfort equipment
Exterior noise suppression measures 	2B1 	Additional exterior noise suppression
Front stabilizer 	0AE 	Front stabilizer
Gearshift knob/handle 	6Q4 	Comfort gearshift knob/handle
General operating permit, alterations 	C25 	Operating permit, alteration
Headlight 	8JS 	Twin headlight for driving on the right with clear lens
Heat accumulator system/additional heater 	7E3 	Sheathed type glow plug heater
Identification plates 	1FF 	Special identification plate (Poland)
Instrument inserts 	U0C 	Instrument insert with tachometer clock and km/h speedometer
Luggage compartment floor covering 	6SC 	Tufted trunk floor covering
Luggage compartment lining 	5A2 	Comfort trunk lining
Luggage net/pocket on backrest(s) 	4U0 	Without luggage nets/pockets on backrests
Lumbar support 	7P0 	Without lumbar support in seat backrests
Manufacturing sequence differentiation 	0FA 	Standard manufacturing sequence
Multi-function display/trip computer 	9Q0 	Without multi-function display/ on-board computer
Nameplate set 	1DG 	Nameplate set "TDI"
Owner's manuals 	0VT 	Information kit in Polish
Protective side molding 	4B1 	Protective side molding
Radios 	8AA 	Without radio
Reading light 	8S8 	2 reading lights
Rear axle 	0N5 	Standard rear axle
Rear headrests 	3Q1 	Rear headrests
Rear stabilizer 	0BB 	Rear stabilizer
Seat adjustment 	3L1 	Manual height adjustment for left front seat
Seat covering 	N4C 	Fabric seat covering
Service interval prolongation 	QG2 	No possibility of activating service interval prolongation
Shock absorption, chassis, front 	G38 	Front shock absorption
Shock absorption, chassis, rear 	UB8 	Rear shock absorption
Side air bag 	4X0 	Without side air bag
Socket 	7B0 	Without socket
Spare wheel/breakdown set 	1G2 	Steel spare wheel with original equipment tires
Special labels/plates 	0SB 	Labels/plates in German
Steering 	1N1 	Power steering
Steering wheels 	1MP 	Steering wheel for air bag system
Tires 	H6S 	Tires 195/65 R15 V
Type approval countries/countries with special requirements 	B17 	Type approval Poland
Weight category front axle 	L06 	Suspension range 06 installation control only, no requirement forecast
Wheel covers 	1ND 	Full wheel covers
Wheels 	C6E 	Steel wheels 6J x 15 Offset 38
Windshield glass type 	4GC 	Windshield in heat-insulating glass with sunshield
 	P04
 	PH4
 	PR8
Front seats 	Q1A 	Standard front seats Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam. prosze o pomoc
WVWZZZ19ZHW376732
									WVWZZZ19ZHW376732
vw jetta mk1 coupe EX
vw golf mk2 1.8 automat :) +lpg
Niestety za stare auto, nie ma w bazie.lunatic pisze:Witam. prosze o pomoc
WVWZZZ19ZHW376732
Moge prosic o sprawdzenie jeszcze tego nr vin
WVWZZZ3BZ3P193308
z gory dzieki.
									WVWZZZ3BZ3P193308
z gory dzieki.
olivier85 pisze:Moge prosic o sprawdzenie jeszcze tego nr vin
WVWZZZ3BZ3P193308
z gory dzieki.
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ3BZ3P193308
Model Designation	passat saloon
Model	PA
Date of production	29.08.2002
Model year	2003
Sales type	3B3161
Engine code	AWX
Transmission code	FHN
Axle drive	5S
Interior trim code	GC
Roof color	Z4
Additional body covers, side 	6EP 	Additional stone guard body covers
Additional child seat anchors 	3B4 	Child seat anchor for child seat system ISOFIX
Batteries 	J0R 	Battery 380 A (80 Ah)
Body style 	K8B 	Notchback
Brake type, front 	1ZC 	Disc brakes, front (Geomet D)
Brake type, rear 	1KD 	Disc brakes, rear
CD changer/CD player 	7A8 	CD changer (front)
Catalytic converter control 	8KA 	W/o catalytic converter warning light
Center rear seat belts 	3C3 	Lap belt with retractor for the center rear seat
Cruise control warning and speed limit system 	6Y0 	Without cruise control warning system
Door and side trim panels 	3LD 	Door and side trim panel
Double-size standard radio/dual-view display 	2T1 	Double-sized standard (DIN)
Duty-free tires 	1V0 	Without duty-free and cost-free tires
Flame retardent materials 	4Q0 	No flame retardent materials
Floor coverings 	3MQ 	Ibolours floor covering
General operating permit, alterations 	C06 	Operating permit, alteration
Heat accumulator system/additional heater 	7E6 	Electric auxiliary air heater
Insert for the filling up of unleaded fuel/fuel type 	2G0 	Without insert for the filling up of fuel
Installation parts for engine (engine mount system) 	1VG 	Installation parts for four-cylinder engine
Luggage compartment floor covering 	6SD 	Tufted trunk floor covering (dimensionally stable)
Malfunction display 	9HA 	Without additional malfunction display
Manufacturing sequence differentiation 	0FG 	Mosel manufacturing sequence
Mass damper for steering wheels 	1Q1 	Mass damper for steering wheel, 26.5Hz
Moldings 	4ZB 	Bright moldings
Paint coating 	FB3 	Surface, interior trim, soft-touch paint
Parking light indicator light 	8NA 	Without parking light warning light
Radios 	8AR 	Radio "gamma" with removable operating panel
Reading light 	8S4 	Two reading lights front, two rear
Rear cargo area 	3GK 	Without additional lower part for luggage compartment floor
Rear seats 	3NZ 	Rear seat bench unsplit, backrest split folding
Safety certificate 	0LA 	Without special plates/stickers/ safety certificates
Seat covering 	N0U 	Cut pile seat covering
Shock absorption/suspension, chassis 	1BA 	Standard suspension/shock absorption
Side lights 	8F2 	Side turn signal lights
Ski bag 	3X0 	Without load-through provision
Smoking/non-smoking package 	9JA 	Non-smoking package
Socket 	7B3 	12-volt socket(s)
Transmission shafts 	1WD 	Transmission shaft for tripod joints
Transmission shafts, rear axle 	1YA 	Without transmission shafts f. rear axle
Transmission specifications 	G0C 	5-speed manual transmission
Transmission types/gearshift mechanisms 	0G1 	Gearshift lever
Vehicle class differentiation units/platform components 	0DE 	Installation differentiation for build status of vehicle class B5 (VW Passat)
Weight category front axle 	0JH 	Weight category front axle weight range 8
Weight category rear axle 	0YD 	Weight range 4 installation control only, no requirement forecast
Wheel covers 	1NC 	Full wheel covers
Wheels 	C5E 	Alloy wheels 8.5J x 19
Window regulator 	4R3 	Power windows with comfort operation
Windshield glass type 	4GH 	Windshield in heat-insulating glass with sunshield
 	PCW
 	PH2
Front seats 	Q2J 	Comfort front seats
 	RCH
Hands-free system 	VX0 	Without hands-free system
Tire suppliers 	V0A 	Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
						Re: PROŚBA O SPRAWDZENIE NUMERU VIN
kameln pisze:Witam, prosze o sprawdzenie numeru VIN WVWZZZ1KZAW144415
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1KZAW144415
Model Designation	golf 2.0 blue motion
Model	GOLF
Date of production	23.09.2009
Model year	2010
Sales type	5K134N
Engine code	CBDC
Transmission code	LLL
Axle drive	5S
Interior trim code	FW
Roof color	A1
Exterior color / Paint Code	A1 / 041
"Charism" 	2H0 	Without "drive select"
"Multimedia", video/DVD/notebook connection 	9WL 	Multimedia socket for external audio source
Additional warning lights 	9TC 	Additional reflectors (door area)
Air bag 	4UP 	Driver's and front passenger air bag with knee air bag and front passenger air bag deactivation
Batteries 	J0N 	Battery 330 A (61 Ah)
Battery/alternator capacity 	NY0 	Standard battery/alternator capacity
Brake type, front 	1ZF 	Disc brakes, front (Geomet D)
Braking systems 	1AC 	Anti-lock brake system (ABS)
Breakaway interior mirror 	4L6 	Breakaway interior rear view mirror, automatically dimming
Climatic zones 	0Y1 	Standard climatic zones
Customized installation 	FC0 	Without customized installation
Delivery equipment 	2A0 	Without delivery equipment
Doors 	0A2 	4 doors
Emission standard 	7MG 	Emission standard EU5
Engine specifications 	D96 	4-cyl. turbo dies. eng. 2.0 l/81 kW (4V) TDI common rail Base engine is TG3/TP4/TU3/TL4
Exhaust tailpipe 	0P1 	Rear side exhaust tailpipe
Fuel systems 	0F3 	Fuel system for diesel engine
Fuel tank treatment 	2LD 	Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Gearshift knob/handle 	6Q2 	Leather gearshift knob/handle
General operating permit, alterations 	C32 	Operating permit, alteration
Headlight activation 	8K3 	Separate daytime running lights with low beam assistant and "Coming Home" feature
Headlight-range adjustment 	8Q4 	Headlamp range adjustment with fixed bending light
Headrests 	3J1 	Height-adjustable headrests for front seats
Inserts 	5MB 	Decorative inserts
Installation differentiation for vehicle components 	0EJ 	Installation differentiation for transmission MQ 250 vehicle components
Interior light in foot area 	6T1 	Interior light in footwell
Lockable wheel bolts 	1PE 	Wheel bolts with anti-theft protection (unlockable)
Multi-function display/trip computer 	9Q5 	Multi-function display with control
Operating voltage 	9Z0 	Operating voltage 12V
Outer rear seat belts 	3ZB 	3-point seat belts, outer rear with ECE label
Paint preservative/transit coating 	5K7 	Transport protection film (minimum protection) with additional transport protection measures
Radiator grille 	6KC 	Radiator grille
Radios 	8AE 	Radio "RCD310 MP3"
Rear headrests 	3T2 	Three rear headrests
Rear seats 	3NU 	Rear seat bench unsplit, backrest split folding with center armrest
Rear spoiler 	5J0 	Without rear spoiler
Rear stabilizer 	0BE 	Rear stabilizer
Refrigerator 	1W2 	Glove compartment cooling system
Rough-road/sports version 	2UC 	Sports version
Safety headrest system 	3K0 	Without safety headrest system
Scuff plates 	7M5 	Without protective film for scuff plate
Seat belt check 	9P3 	Seat belt reminder, electric contact in buckle
Seat covering 	N3B 	Fabric seat covering
Shock absorption, chassis, front 	G02 	Front shock absorption
Shock absorption, chassis, rear 	1JC 	Rear shock absorption for sports design
Side and rear windows 	4KF 	Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
Spare wheel/breakdown set 	1G6 	Space-saving spare wheel
Special labels/plates 	0SS 	Labels/plates in English and French
Start/stop system/regenerative braking 	7L3 	Without start/stop system without regenerative braking
Steering wheels 	2PP 	Leather multi-function steering wheel
Tires 	H0R 	Tires 205/55 R16 91H optimized rolling resistance
Tool kit and jack 	1S1 	Tool kit and jack
Transmission specifications 	G0J 	5-speed manual transmission different spread of gear ratio
Type approval countries/countries with special requirements 	B08 	Type approval France
Upgrading measures 	GP1 	Vehicles with special upgrade measures
Vehicle class differentiation units/platform components 	0HA 	Vehicle class differentiation 1K0/5K0
Weight category front axle 	L55 	Suspension range 55 installation control only, no requirement forecast
Weight category rear axle 	0YB 	Weight range 2 installation control only, no requirement forecast
Wheels 	CM5 	Alloy wheels 6.5J x 16
Windshield wiper intermittent control 	8N3 	Windshield wiper intermittent control with rain sensor
 	PH2
 	PLA
 	PU2
Base engine 	TU3 	4-cylinder diesel engine 2.0 l Unit 03L.H
Chrome work package 	QJ1 	Chrome work package
Compass/traffic sign display 	QR0 	Without compass/traffic sign display/ traffic signs recognition
Drawers under front seats 	QN0 	Without drawers under front seats
Electric interface for external use 	UF0 	Without electric interface
Hill hold control 	UG0 	Without hill hold control / hill descent control / comfort driving assist
Marten repeller 	UM0 	Without marten repeller
Pedal cluster 	VF0 	Standard pedal cluster
Pedestrian protection 	VL1 	Extended pedestrian protection measures
 	RGC
Control number (no PR-Family) 	S5K 	Control (in-plant)
				MARIUSZW180
Witam,
Proszę o sprawdzenie historii auta nr vin WV1ZZZ2DZ6H036918
Z góry dziękuje
Z góry dziękuje
