Panowie mam pytanko, powiedzcie mi czy jest mozliwosc wyłączernia poduszki powietrzbnej pasazera w golfie IV , kolega ma takie auto i chce ja odlaczyc poniewaz chce zamontowac fotelik, a podobno nie moze byc wowczas wlaczona poduszka.
pzdr
wyłączenie poduszki
raczej nie, można wyłączyć selektywnielooki8329 pisze:będą wyłączone wszystkie
1) determine if your car can do this. Use VAG-COM (or equivalent) to access the airbag controller. Look at the Component box in the upper right corner. In the middle of the string you should see 'VWx' where x is a number. This number must be 5 or higher. Anything lower requires a special resistance kit installation (1J0 998 521). An exception to this is VW3 with part number 1J0 909 609. This controller does not require the resistance connector.
2) Click on 10-Adaptation
3) Click up for the channel number to get to channel 01. This is the passenger front airbag channel. The value is 0 (zero) for 'enabled'. Click the up arrow to make it a '1'. Click 'Save' and confirm the prompt. This will disable that airbag.
For the other airbags, disabling them is a matter of choosing a different channel.
1 - passenger front
2 - driver front (steering wheel)
3 - passenger side (seat airbag)
4 - driver side
5 - passenger belt tensioner
6 - driver belt tensioner
7 - passenger head
8 - driver head
Enabling the airbag is just a matter of performing the same steps but decrementing the channel value from 1 to 0.
When an airbag is disabled, the airbag light will light on the cluster for the normal 4 seconds when you first turn the starter key to the on position, then additionally flash for 12 seconds.
inny temat na forum http://forum.vwgolf.pl/viewtopic.php?t= ... 3ea2ab45cc
Ostatnio zmieniony wt paź 27, 2009 18:11 przez Oli, łącznie zmieniany 1 raz.
[b]148KM/326Nm[/b]
Użytkownicy przeglądający to forum: Bing [Bot] i 149 gości
