Model: A4
Typ nadwozia: Avant
Generacja: B8
Rodzaj silnika: 2.0TDi (125kW / 170PS) 4 cyl.
Kod silnika: CAHA
Skrzynia: JST
Lakier: szary metalik
Kokpit: ciemny grafit
Tapicerka: szara
Produkcja: 11.2008 (face lifting 2009)
Data pierwszej sprzedaży: 02.2009
Model sprzedażowy: 8K5 0RC
Stan: skasowany / szkoda całkowita
W standardzie:
E0A = No special edition
7A3 = CD player
4UE = Air bag for driver and front seat passenger
6XK = Exterior mirrors: automatically dimming,electrically foldable/adjustable/heated
5SL = Left exterior mirror: aspherical
6TS = Right exterior mirror: aspherical, large viewing field
1KW = Disc brakes, rear
J0Z = Battery 520 A (110 Ah)
1LT = Disc brakes, front
1AT = Electronic stabilization program (ESP)
1BA = Standard suspension/shock absorption
3FA = Without roof insert (standard roof)
5MA = Decorative inserts
7X4 = Park distance control, front and rear
F0A = No special purpose vehicle, standard equipment
8GU = Alternator 140 A
0G1 = Gearshift lever
0YH = Weight range 8 installation control only, no requirement forecast
0JG = Weight category front axle weight range 7
TH3 = 4-cylinder diesel engine 2.0 L unit 03L.B
3NZ = Rear seat bench unsplit, backrest split folding
8BD = Halogen headlight
U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
X0A = National sales program Germany
1N1 = Power steering
2ZQ = Leather trimmed multi-function steering wheel for air bag system
8Q1 = Headlight-range adjustment
9Q4 = Multi-function display/on-board computerwith check control
8Z5 = Not hot country
D93 = 4-cyl. turbo dies. eng. 2.0 l/125 kW 4V TDI common rail Base engine is TG3/TH3/TL4/TM4/TP4/TU3
7Q2 = Navigation system with color screen
C3U = Alloy wheels 7.5J x 16 offset 45
7K6 = Flat tire indicator
4X3 = Side air bag front with curtain air bag
2K1 = Reinforced bumpers
3L3 = Manual height adjustment for front seats
4KC = Side and rear windows in heat-insulatingglass
3Y4 = Roll-up sun screen for rear side windows
4K4 = Radio remote controlled central locking
5D7 = Carrier frequency 868 MHz without panic button
1SA = Without additional front underbody guard
7MG = Emission standard EU5
Q1A = Standard front seats
4GF = Windshield in heat-insulating glass
kody zdekodowane przy pomocy strony: link
oraz reszta:
- trzy-strefowy klimatronic
- system otwierania i zamykania klapy bagażnika na przycisk
- tempomat
- wbudowany zestaw głośnomówiący bluetooth + złącze do.pzystawki pod telefon
- podświetlanie dywaników przy wsiadaniu i wysiadaniu
- system go-home (podświatlanie terenu przy wsiadaniu i wysiadaniu)
Mody:
- hardmod: czerwona wlepa vwgolf.pl bez oznaczenia grupy (lewy dolny róg klapy)
- hardmod: felgi 18"
- hardmod: instalacja modułu AMI do obsługi urządzeń Apple
- softmod: aktywacja menu diagnostycznego mmi
- softmod: spolszczenie menu (downgrade 5.5.7.0 -> 5.1.5.0) no i powrót do 5570
- softmod: doświetlanie zakrętów światłami przeciwmgłowymi
- softmod: test liczników przy włączeniu zapłonu - efekt jak w (R)S4
- softmod: aktywacja stopera okrążeń
- softmod: MMI startuje z logo Audi S4
W dniu 14.07.2013 samochód wziął udział w wypadku. Zdjęcia po dostępne na mojej stronie: http://biczan.pl
