Logi dynamiczne AHU notlauf
Wszelakie info dotyczące diagnostyki,takie jak np.oceny logów itp.
Moderatorzy: italiano_83, G0 Karcio, Haki, Qto, marcin7x5, VIP
krissMK4
TDI - The Devil Inside
Post autor: krissMK4 » czw sie 17, 2017 19:03
Prosiłbym o analizę logów pacjent passat B5 1.9TDI AHU . przy 120km/h notlauf
wywala błąd
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
Dynamiczne :
Grupa 011: http://vaglog.pl/log-011_z21r8.html" onclick="window.open(this.href);return false;
Grupy 003, 008, 011: http://vaglog.pl/log-003_008_011_wt9CFI3.html" onclick="window.open(this.href);return false;
Grupa 003: http://vaglog.pl/log-003_q32tB6.html" onclick="window.open(this.href);return false;
Grupa 004: http://vaglog.pl/log-004_40S02iT.html" onclick="window.open(this.href);return false;
Grupa 008: http://vaglog.pl/log-008_bl04av.html" onclick="window.open(this.href);return false;
Grupa 010: http://vaglog.pl/log-010_m04ix.html" onclick="window.open(this.href);return false;
Statyczne :
Grupa 000: http://vaglog.pl/log-000_9neV2I.html" onclick="window.open(this.href);return false;
Grupa 001: http://vaglog.pl/log-001_d2BiV.html" onclick="window.open(this.href);return false;
Grupa 003: http://vaglog.pl/log-003_Lc6NX.html" onclick="window.open(this.href);return false;
Grupa 004: http://vaglog.pl/log-004_SwPJ1.html" onclick="window.open(this.href);return false;
Grupa 007: http://vaglog.pl/log-007_Q86n5j.html" onclick="window.open(this.href);return false;
Grupa 013: http://vaglog.pl/log-013_6B8mEZ.html" onclick="window.open(this.href);return false;
Basic settings:
Grupa 011: http://vaglog.pl/log-011_24BV0.html" onclick="window.open(this.href);return false;
Grupa 000: http://vaglog.pl/log-000_sraYq.html" onclick="window.open(this.href);return false;
Grupa 003: http://vaglog.pl/log-003_5vUf2VW.html" onclick="window.open(this.href);return false;
Grupa 004: http://vaglog.pl/log-004_1uWz7T.html" onclick="window.open(this.href);return false;
Z góry dzięki za pomoc .
Znajdź przyczynę, rozwiąż problem
Bo inaczej za daleko nie pojedziesz już tym golfem ;)
bioly05011
VWGolf.pl Killer
VWGolf.pl Killer
Post autor: bioly05011 » pt sie 18, 2017 07:36
logi robiłeś na zimnym silniku?,kąt za duży,jeśli silnik był rozgrzany,dawkę masz za mała,możesz podmienić n75 z n18 na próbę,sprawdź... dodam jeszcze byś sprawdził wężyki podciśnienia
krissMK4
Post autor: krissMK4 » pt sie 18, 2017 07:45
Czujnik temp jest uszkodzony ,przed logami auto zrobiło 20km , i na liczniku było 90 stopni
Kąt wtrysku za duży to wiemy
nie da rady podmienić n75 bo jest kwadrat http://www.idparts.com/images/N75_A3B4_451.jpg" onclick="window.open(this.href);return false;
a n18 jest https://encrypted-tbn0.gstatic.com/imag ... bL5EmYd03b" onclick="window.open(this.href);return false;
bioly05011
VWGolf.pl Killer
VWGolf.pl Killer
Post autor: bioly05011 » pt sie 18, 2017 09:02
podciśnienia sprawdź
krissMK4
Post autor: krissMK4 » pt sie 18, 2017 12:49
tam jest nadciśnienie , bo dmucha z węży , wszystkie węże całe , teraz jesteśmy na etapie podmiany n75
bioly05011
VWGolf.pl Killer
VWGolf.pl Killer
Post autor: bioly05011 » pt sie 18, 2017 14:14
wiem turbo bez zmiennej...
krissMK4
Post autor: krissMK4 » wt sie 22, 2017 17:13
Problem rozwiązany .
Uszkodzony zawór N75
Wróć do „Diagnostyka”
