Golf AJM 2001 duzo pali po UPG
waadimch
Post autor: waadimch » wt gru 28, 2010 20:10
witam
posiadam vaga znajomy przyjechal do mnie golfem bym stwierdzil dlaczego tak duzo pali ok 10 oraz ma problemy z odpalaniem
przeczytalem mase podobnych tematow ale sadze ze pomoze mi tylko ocena logow przez was
pozdrawiam
ps ponizej wszystkie mozliwe logi
http://vaglog.rtnet.pl/waadimch_30821.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30822.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30823.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30824.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30825.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30826.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30827.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30828.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30829.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30830.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30831.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30832.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30833.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30834.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30835.html" onclick="window.open(this.href);return false;
http://vaglog.rtnet.pl/waadimch_30836.html" onclick="window.open(this.href);return false;
damcio151
Post autor: damcio151 » wt gru 28, 2010 22:21
pompowtryski albo nie z tego silnika, albo coś z ich okablowaniem
waadimch
Re: Golf AJM 2001 duzo pali po UPG
Post autor: waadimch » wt gru 28, 2010 22:33
i sadzisz ze mogli podmienic przy tej robocie (upg) i teraz przez to takie cuda sie dzieja spalanie ok 11 i jest slabszy
damcio151
Post autor: damcio151 » wt gru 28, 2010 22:38
może nie podmienili, ale na pewno źle podłączyli elektrykę, lub coś poluzowali
trzeba ściągać pokrywę zaworów i sprawdzić wtyczki od pompek
waadimch
Post autor: waadimch » śr gru 29, 2010 17:39
oki dzis sprawdze pompki zlogowac jakis konkretny kanal jeszcze raz po sprawdzeniu /?
damcio151
Post autor: damcio151 » śr gru 29, 2010 20:33
013. 018, 023
evolution
Post autor: evolution » śr gru 29, 2010 21:44
napisz co dokladnie grzebali w aucie.
z logow widac ze umarly pompki
ale to nie bedzie glownym powodem duzego spalania ani zlego palenia.
napisz ile kolega ma km do pracy
Urodzinowa Promocja!!!
EVOLUTION MOTOR SPORT
damcio151
Post autor: damcio151 » śr gru 29, 2010 22:38
evolution pisze:ale to nie bedzie glownym powodem duzego spalania ani zlego palenia.
nie tak dawno diagnozowałem PDka, pompka była do wymiany ... mechanik wymienił pompkę, ale założył nie pasującą do tego silnika ( sterownika ) , BIPy podchodziły do ponad 100 ... silnik odpalał za 2-3 kręceniem i po chwili gasł , po wymianie problemu nie ma
evolution
Post autor: evolution » śr gru 29, 2010 22:44
musiales miec pompke uwalona, bipy sa zawsze ok jesli pompka jest zdrowa, zmieniaja sie korekcje mg od zlej pompki. nie raz i nie dwa wkladalem dla testu swoja pompke i bipy zawsze sa w okolicach zeroa lub nawet na minusie.
damcio151
Post autor: damcio151 » śr gru 29, 2010 22:51
korekcje były w porządku
evolution
Post autor: evolution » czw gru 30, 2010 19:31
korekcje pompek wcale nie mowia iz pompka jest ok. mowia ze dolna mechanika jest sprawna. o"gorze" mowi wlasnie 23
damcio151
Post autor: damcio151 » czw gru 30, 2010 19:35
evolution, czytaj co napisałem ... korekcje były w porządku, BIP na jednej pompce ponad 100 i były straszne problemy i z paleniem i z chodzeniem na wolnych obrotach .... odpalał po kilkukrotnej próbie , tzn po odpaleniu za 2-3 kręceniem gasł po chwili i tak w kółko , aż w końcu załapał, ale bujało silnikiem jak chciało ... dlatego moje zdanie jest takie, ze prawdopodobieństwo iż to pompki robią problemy z odpalaniem jest duże
evolution
Post autor: evolution » czw gru 30, 2010 19:43
a ja ci poraz kolejny pisze iz nawet bipy 255 nie robia klopotow z odpalaniem, zawsze gada od razu tyle ze buja jak poszesz i w niektorych zaswieca esp. wiec bipy nie sa problemem
damcio151
Post autor: damcio151 » czw gru 30, 2010 19:46
to powiedz to właścicielowi tamtego auta :pub: po wymianie pompki pali i chodzi dobrze
jasne, może pompka była uwalona , ale tak to wyglądało, nie inaczej ... kto wie czy tutaj nie jest podobnie
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 98 gości
