oznaczenia skrzyni 6 biegów pod szpere
Fido_dido
Post autor: Fido_dido » pn lut 15, 2010 01:04
siema
słuchajcie chce przytargać szpere a uesej do mojej skrzyni tdi 6 biegów oznaczenie fmh
pod jaka skrzynie szukac szpery jakie jest jesj oznaczenie ?
O2A O2M O2J czy jak ?
Ostatnio zmieniony pn lut 15, 2010 01:04 przez Fido_dido, łącznie zmieniany 1 raz.
Bling Bling........ rrados TDI Gangster's :D!! Siee Wiee !! Sieeeeeemanko team :D VR6 ynynynyn;]
Dario84
Post autor: Dario84 » pn lut 15, 2010 08:37
http://www.autoshoppingcenter.com/Volks ... speed.html
Wychodzi na to że 02M
CTR Tuning: CHIPTUNING, DIAGNOSTYKA, MECHANIKA, ELEKTRONIKA SAMOCHODOWA, HAMOWNIA GG:3995871 tel 693784122
Mój golfik: MK4 ASZ CTR
NASZE PRACE CTR: http://www.facebook.com/ctrtuning" onclick="window.open(this.href);return false;
Cinek
Post autor: Cinek » wt lut 16, 2010 23:44
tak nie w temacie do końca - ile taka przyjemność ?
viewtopic.php?f=86&t=432970 końca nie ma nigdy...
cowboy
Post autor: cowboy » śr lut 17, 2010 15:11
OBX 249 USD
Peloquin 949 USD
tak na szybko z jebaja
http://shop.ebay.com/?_from=R40&_trksid ... Categories
zaprzal
VW Baron
VW Baron
Post autor: zaprzal » śr lut 17, 2010 15:40
szpera za 300$? ktos testowal OBX?
cowboy
Post autor: cowboy » śr lut 17, 2010 15:42
http://forums.vwvortex.com/zerothread?id=4696366
My summary on OBX LSDs
- They're cheap and cheerful
- Made of some "Chinesium" type material with typical rough casting etc
- You effectively do the manufacturers quality control for them when you receive the unit by stripping, inspecting, cleaning etc.
- Absolutely change the washers and bolts and do the rebuild, it's cheap, easy and at least goes some way to improving reliability. We got ours from Rich who is a really great guy to deal with
http://rbryant.freeshell.org/obx_washers.htm
- What you save in up front cost is offset by time and effort to get them right.
- There's a lot of horror stories on the 'net and plenty of success stories as well. Some people will break them, but then again I know people that can break an anvil with their face.
We've run an upgraded (as above) OBX behind a BT 1.8T for the last 1000 odd kms (err, 650ish miles) including some track work and it's all good so far. How long will it last though? No idea.
FWIW my opinion is if you're after cheap, you're a bit DIY minded and you're willing to take a calculated risk then go for it. If you're paying someone to do all the work and you want reliability then pay the extra and buy a proven product you can just have fitted and go driving.
wesol
Post autor: wesol » śr lut 17, 2010 20:25
ilu procentowa ta szpera bo to tez wazne jest.
Wróć do „TDI”
