Zna ktoś to R32?? - ogłoszenia sprzedaży golfów R
Ciekawa oferta, po vinie się wszystko zgadza nawet
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ3D503471
Model Designation golf r32
Model GOLF
Date of production 24.04.2003
Model year 2003
Sales type 1J1RZ7
Engine code BFH
Transmission code GQV
Axle drive 6S
Interior trim code JZ
Roof color C7
Exterior color / Paint Code C7 /
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UE Air bag for driver and front seat passenger
Antennas 8L3 Roof antenna
Anti-theft protection system 7AP Electronic vehicle immobilization device w/ alarm syst., passenger comp. control, backup horn and all door opening
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H9 Backrest release for front seats with "Easy Entry"
Batteries J1L Battery 280 A (60 Ah)
Body measures 5C3 Body measures for increased safety requirements
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1ZT Disc brakes, front
Brake type, rear 2EL Disc brakes, rear
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Bumper 2JF Painted bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E0 Without center armrest front
Center rear seat belts 3C1 Static lap belt, center rear
Chrome work package QJ1 Chrome work package
Component part sets with country-specific design requirements B0F Component parts set, complying with vehicle type for Switzerland, various parts
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T2 Cruise control system (CCS) electronic
Cup holder 4M6 Cup holder
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
Door pockets, front 3YR Door pockets with insert mats
Doors 0A1 2 doors
Drive layout 1X1 Four wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GG Emission standard EU4
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine specifications D9J 6-cyl. gas. eng. 3.2 L/177 kW 24V VR6 base engine is T31/T36/T3D
Equipment levels A9R Top sports
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor coverings 3MF Dilours floor covering with scuff guard
Floor mats 0TD Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WA Without front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Front stabilizer 0AT Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 7F3 Leather/wooden gearshift knob
General operating permit, alterations C30 Operating permit, alteration
Generators 8GL Alternator 120 A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8JM Twin headlight for driving on the right, with integrated high beam
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X1 Headlight washer system
Headlight-range adjustment 8Q2 Automatic headlight-range adjustment static
Headrests 3J9 Headrest for front seat
Heat accumulator system/additional heater 7E2 Heated crankcase ventilation system
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5MD Decorative aluminum inserts
Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
Left exterior mirror 5SC Left exterior mirror: aspherical (modified viewing field)
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SM Needle-punched trunk floor covering (Dilours)
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FK Bratislava manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 2RC Nameplate set "R32" (without model designation)
Nameplates for sales name QD0 Without lettering for sales name
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Owner's manuals 0XX Information kit in German (for export)
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KG Radiator grille
Radios 8UT Radio "delta" (double-size standard radio)
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N5 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3T6 2 rear headrests height-adjustable
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NC Rear seat bench/backrest, split folding
Rear stabilizer 0BU Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RC Right exterior mirror: convex (modified viewing field)
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Rough-road/sports version 2UA Standard design
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P0 Without seat belt reminder
Seat covering N0Z Alcantara seat covering, side facings and seat insert in full leather
Seat heater 4A3 Seat heater for front seats separately controlled
Service interval prolongation QG1 Service interval prolongation
Shock absorption, chassis, front G90 Front shock absorption
Side air bag 4X3 Side air bag front with curtain air bag
Side and rear windows 4KQ Side and rear windows in heat-insulating glass (blue)
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B0 Without socket
Spare wheel/breakdown set 1G8 Breakdown set
Speaker installation 8RM 8 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SB Labels/plates in German
Special registration measures 3M0 Without special measures
Steering QZ6 Power steering (uprated compression spring a. limited steer. lift mechanism)
Steering column systems 2C2 Axial and vertical adjustable steering column (reinforced)
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 1MW Leather steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tires H3L Tires 235/60 R18 ??? front tires 255/55 R18 ??? rear
Tool kit and jack 1S3 Tool kit
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0L 6-speed manual transmission for four-wheel drive vehicle
Transmission types/gearshift mechanisms 0G5 Gearshift lever
Tray 7N0 Without tray on roof liner
Type approval countries/countries with special requirements B13 Type approval Switzerland
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Vehicle type AZ3 Special chassis package
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L92 Suspension range 92 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheel covers 1NL Covers for alloy wheels
Wheels CU7 Alloy wheels 7.5J x 18
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GT Heat-insulating glass windshield
Windshield wiper intermittent control 8N3 Windshield wiper intermittent control with rain sensor
PL2
PS4
Child seats QA0 Without child seat
Front seats Q1J Sports front seats
RDA
Air duct, front area VK6 Air duct, type 6
Base engine T3D 6-cylinder gasoline engine 3.2 L unit 022.E
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Shock absorption, chassis, rear UB7 Rear shock absorption for sports design
Tire suppliers V0G MICHELIN tires Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
- Radas
dokładnie tak. Byłem widziałem nawet jechałem.KonradzikIV pisze:było już oglądane przez kolege Radas więc on może się wypowiedzieć na ten temat
Kolor ciemny granat, szary srodek z normalnymi śladami użytkowania.
Auta tak jak w opisie ma tam jakies odpryski na zderzaku, szybie. W środku nic nie jest powycierane co na moje świadczy o realnym przebiegu 63 tys. Właściciel auto serwisuje wymieniał ostatnio łożyska i jakieś kable czy cewki w ramach akcji serwisowej. Zawieszenie ok, silnik chodzi ładnie, sprzęgło również nigdzie nie ma żadnych stuków zgrzytów czy czegoś innego z wydruku z geometrii robionej w serwisie wynika że auto proste nie zostawia 4 śladów, oponki prawie nówki jeszcze na gwarancji felgi OZ Aristo w stanie bdb. Lekko źle spasowany przód tj do ustawienia lampy maska z błotnikiem, widać że auto musiało się pod coś wsunąć bo faktycznie nie ma śladów na podłużnicy, kielichu czy na zawieszeniu - (na pierwszy rzut oka bo dokładnie nie sprawdzałem trzeba by wjechać na kanał i popatrzeć ale właściciel widać nie ma nic do ukrycia). Właścicielem jest młody gość ale z historii jaką mi przedstawił i pokazał na foto nie jest to jego pierwsze auto powiedzmy sportowe ( RS4, 350Z, Leon Cupra) z resztą bardzo w w porządku gość z którym można pogadać.
Na razie się nie napalać
Z tego co mi wiadomo autko chwilowo zarezerwowane wiec Panowie trzeba sie trochę ostudzić
- xxxPALUCHxxx
______LET's GOLF______
MIGAJACA KONTROLKA AKUMULATORA / ALTERNATORA -> potrzebuje pomocy :
viewtopic.php?f=140&t=398583
- Radas
xxxPALUCHxxx, dokładnie tak jak piszesz obecny właściciel kupił auto 8 miesięcy temu od znajomego z Brzegu może to są fotki z jakiejs tam aukcji wystawionej przez tego drugiego.
Re: Zna ktoś to R32?? - ogłoszenia sprzedaży golfów R
Radas pisze:xxxPALUCHxxx, dokładnie tak jak piszesz obecny właściciel kupił auto 8 miesięcy temu od znajomego z Brzegu może to są fotki z jakiejs tam aukcji wystawionej przez tego drugiego.
Radas na tych fotach jednak widać że z lusterkami jest coś nie tak ale chyba te od kierowcy jest od zwykłej golfiny czyli dłuższe
No na tych zdjęciach ta R ma ewidentnie lusterka Duże + Małe, a nie eRkowe.
No ale na tych z aukcji już ktoś usunął brak
- pavo71
Zdjecia sa sprzed około poł roku tak ? to ladnie ktos nia jezdziło skoro zrobil ponad 30 tys km
- Radas
złudzenie też tak myślałem na pierwszy rzut oka, ma dwa ori RRafit pisze:No na tych zdjęciach ta R ma ewidentnie lusterka Duże + Małe, a nie eRkowe.
zdjęcia z 2009 roku kiedy poprzedni właściciel kupił to auto ze Szwajcariipavo71 pisze:Zdjecia sa sprzed około poł roku tak ? to ladnie ktos nia jezdziło skoro zrobil ponad 30 tys km
- xxxPALUCHxxx
to swiadczy tylko o tym ze R32 nadaje sie do jazdy na codzienRadas pisze:Zdjecia sa sprzed około poł roku tak ? to ladnie ktos nia jezdziło skoro zrobil ponad 30 tys km
A dlaczego ma się nie nadawaćxxxPALUCHxxx pisze:to swiadczy tylko o tym ze R32 nadaje sie do jazdy na codzien
www.proturbo.com.pl
- Radas
jest moneta jest zabawa hehedaniel1d pisze:A dlaczego ma się nie nadawaćJa swoim robiłem po kilka tyś miesięcznie.
ja zawsze myslalem z erka ma duze lusterka w stabdardowym romiarze jak normalny golf tyle ze prawe tez duze a tu sie dowiaduje ze byly jeszcze jakies typowe erkowe srednich rozmiarow tak?
