Problem z temperatura cieczy lub licznikiem
greg
- bartek1351
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 HH
Component: 1,9l R4 EDC 0000SG 1491
Coding: 00003
Shop #: WSC 31414
VWZ6Z0B0209949
1 Fault Found:
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 N
Component: ESP ALLRAD MK60 0102
Coding: 0023046
Shop #: WSC 31414
3 Faults Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure - Intermittent
008 - Implausible Signal
005 - No or Incorrect Basic Setting / Adaptation
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31414
1 Fault Found:
00281 - Vehicle Speed Sensor (G68)
37-00 - Faulty
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 826 C
Component: KOMBI+WEGFAHRS. RB8 V24
Coding: 05114
Shop #: WSC 00090
VWZ6Z0B0209949
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31414
No fault code found.
Address 22 -------------------------------------------------------
Controller: 02D 900 554 C
Component: HALDEX LSC ECC 0010
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 07401
Shop #: WSC 00066
End -------------------------------------------------------
Coding: 00003
Shop #: WSC 31414
VWZ6Z0B0209949
1 Fault Found:
P0501 - 35-00 - -
Readiness: N/A
Coding: 0023046
Shop #: WSC 31414
3 Faults Found:
Coding: 11000
Shop #: WSC 31414
1 Fault Found:
37-00 - Faulty
Coding: 05114
Shop #: WSC 00090
VWZ6Z0B0209949
1 Fault Found:
Coding: 00006
Shop #: WSC 31414
Coding: 07401
Shop #: WSC 00066
Ostatnio zmieniony czw cze 18, 2009 13:22 przez bartek1351, łącznie zmieniany 1 raz.
153KM/328Nm
GOLF MK7 1.6TDI CLHA+
- bartek1351
impulsator wymieniony, pomoglo
Ostatnio zmieniony śr lis 18, 2009 08:57 przez bartek1351, łącznie zmieniany 1 raz.
153KM/328Nm
spróbuj parę razy w lewo i prawo do oporu skręcić,nieraz pomagabartek1351 pisze:tak ale kasowanie nie pomaga, odnosnie czujnika skretu
[ Dodano: 14 Cze 2009 20:57 ]
podczas powolnej jazdy
- bartek1351
Impulsatory wymieniony na nowy, czujnik skretu naprawiony. Bledy skasowane i licznik nadal stoi w miejscu :/Qto pisze:Tak jak kolega greg napisał, impulsator bankowo do wymiany
Są jeszcze błędy czujnika temperatury i czujnika kąta skrętu kół, próbowałeś kasować te błędy?
153KM/328Nm
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 161 gości
