Mam nietypowy problem z autem Polo 6r poniewaz wyskakuje ,,lampa alladyna" aczkolwiek nie wiem który z tych błedów moze byc za to odopowiedzialny.
VCDS Version: Beta 11.6.0
Data version: 20111008
Monday,14,September,2020,00:30:00:10074
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 44 55 56 69 0B
VIN: WVWZZZ6RZCY530932
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CBZB) Labels: None
Part No SW: 03F 906 070 HE HW: 03F 907 309 J
Component: SIMOS10.22AH10 2684
Revision: --H10--- Serial number:
Coding: 001900D6200400080000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM12TFS02103F906070HE 004004
ROD: N/A
VCID: 6CD3C083344B
No ASAM data for: "EV_ECM12TFS02103F906070HE" (VW25)
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 210228E3217000B2842E14E584D300401300
Shop #: WSC 00788 648 00255
VCID: 87191F2F8DED
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387B2CD33093
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 83807 km
Time Indication: 0
Date: 2026.14.05
Time: 08:23:08
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0251
Revision: BS050001 Serial number: 0465 264110975
Coding: 24B029BF08A10000092008916C2B0FD05A40672F60051041200000010000
Shop #: WSC 124697 483 00190
VCID: 397D29D70B99
Subsystem 1 - Part No: 1K0 955 559 AH
Component: RLS 051011 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB
Component: J386__TSG_FT 008 1621
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
Component: J387__TSG_BT 008 1621
Coding: 08BC30
Subsystem 4 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS25.255 H02 0007
Coding: 081001
Address 15: Airbags (J23) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01K H09 0020
Revision: -------- Serial number: 003GX00WSGRQ
Coding: 00314B
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4A9F661B5E7F
Driver's Airbag Crash Sensor:
Serial number: 3575HRB40590Q4PG79GO
Passenger Side Airbag Crash Sensor:
Serial number: 3585HRB40590Q4PG6HGW
Driver's Rear Airbag Crash Sensor:
Serial number: 3515RRB405P0OPMKG1KQ
Passenger's Rear Airbag Crash Sensor:
Serial number: 3525RRB405J0OPMKO90H
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
Component: KOMBI H03 0505
Serial number: 00000000000000
Coding: 140C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 397D29D70B99
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 H50 0251
Revision: BS050001
Coding: 002000
VCID: F0EB54F39863
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 83807 km
Time Indication: 0
Date: 2026.14.05
Time: 08:24:39
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0505
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EADF469BBEBF
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F69178FC5DD
Address 55: Xenon Range (J431) Labels: None
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: F7F96FEFFD0D
Address 56: Radio (J503) Labels: None
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 031 0075
Revision: 01000001 Serial number: VWZ1Z2L3545685
Coding: 05000400020001
VCID: 33611BFF29F5
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 83807 km
Time Indication: 0
Date: 2026.14.05
Time: 08:25:27
Address 69: Trailer
Cannot be reached
Address 0B: Sec. Air Heating
Cannot be reached
End ---------------------------------------------------------------------
[inny] Nietypowy problem.../Logi
Moderatorzy: italiano_83, G0 Karcio, Haki, Qto, marcin7x5, VIP
[inny] Re: Nietypowy problem.../Logi
Odczyt błędów tu nic nie pomoże. Kontrolka ciśnienia oleju świeci ponieważ jest za niskie ciśnienie, spowodowane np.: niskim stanem oleju. Jeżeli poziom jest w porządku, to jest kilka możliwości: uszkodzona pompa oleju nie daje właściwego ciśnienia, zapchany filtr oleju, zapchane sitko na pompie oleju, itp. Może też być uszkodzony czujnik ciśnienia oleju.
xkoksiarzx
Witam serdecznie, potrzebuję login do sterownika silnika VW Golf 3 1.6 8v 75KM AEE 1996r, nigdzie nie mogę znaleźć informacji na ten temat. Bardzo proszę o pomoc.
To nie ligi tylko autoscan. Te odczyty błędów musiałby raczej być robione wtedy gdy ta kontrolka się pali aktualnie to raz i dwa raczej z modułu silnika.
