logi z Golf V 1.6 FSI
Wszelakie info dotyczące diagnostyki,takie jak np.oceny logów itp.
Moderatorzy: italiano_83, G0 Karcio, Haki, Qto, marcin7x5, VIP
meikergolf
Post autor: meikergolf » wt kwie 11, 2017 19:17
Witajcie, zrobiłem skan i pomoże ktoś rozszyfrować?
Tuesday,04,April,2017,20:56:40:10074
VCDS Version: 11.6.0
Data version: 20111008
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ4W113300 Mileage: 122650km/76211miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03C-906-056-BAG.lbl
Part No SW: 03C 997 056 M HW: Hardware No
Component: MED9.5.10 00 9265
Revision: 00000000 Serial number: VWZ7Z0D9459810
Coding: 0000072
Shop #: WSC 00140 259 88093
VCID: 37792FEF3D8D
2 Faults Found:
18702 - Oxygen (Lambda) Sensor Signal B1 S2: too Lean
P2270 - 001 - Upper Limit Exceeded - Intermittent
17441 - Sensor for NOx (G295): Signal too Low
P1033 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
Shop #: WSC 01392 785 00200
VCID: 3D753DC71FB1
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
VCID: 2F69178FC5DD
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000555724
Coding: E58D0F0600041800001400001400000000
VCID: 387B2CD33093
Subsystem 1 - Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 K
Component: RegenLichtSens 002 0505
Coding: 00217125
Shop #: WSC 00000
1 Fault Found:
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 A HW: 1K0 909 605 A
Component: 0L AIRBAG VW8 022 0500
Revision: 04022000 Serial number: 0033FD09UFXZ
Coding: 0012364
Shop #: WSC 01371 785 00200
VCID: 2A5F069BFE3F
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: 306B14F3D8E3
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 860 K
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0001101
Shop #: WSC 00140 259 21637
VCID: 306B14F3D8E3
1 Fault Found:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001042280287
Coding: 3D3F0340070002
VCID: 2759FFAFED2D
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 17
Reset counter: 234
Mileage: 122227 km
Time Indication: 0
Date: 2000.00.00
Time: 07:30:07
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3354
VCID: 306B14F3D8E3
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0115
Coding: 0000052
VCID: 306B14F3D8E3
1 Fault Found:
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.1 1301
VCID: 2E570A8BC2D7
1 Fault Found:
Freeze Frame:
Mileage: 2640 km
Temperature: 13.0°C
Voltage: 11.90 V
Voltage: 11.70 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 18E802087F2D8404084F0100
Shop #: WSC 00570 259 09939
VCID: 306B14F3D8E3
1 Fault Found:
00668 - Supply Voltage Terminal 30
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
VCID: 316D11F7D3E9
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 J
Component: Radio BNO 0016
Coding: 0040400
VCID: 2D550D87CFD1
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0202
Coding: 0000016
VCID: 306B14F3D8E3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
VCID: 316D11F7D3E9
End ---------------------------------------------------------------------
doggie
Silnik: TSI
Post autor: doggie » sob kwie 15, 2017 22:06
to nie są logi tylko autoscan, poza tradycyjnymi błędami związanymi z czujnikami NOX w FSI nic szczególnego nie ma, jakieś pozostałości po odpięciu akumulatora, wykasuj i sprawdź czy wracają
meikergolf
Post autor: meikergolf » pn kwie 17, 2017 20:03
Ten czujnik należy wymienić? Wychodzi też często błąd lambda 2.
doggie
Silnik: TSI
Re: logi z Golf V 1.6 FSI
Post autor: doggie » wt kwie 18, 2017 17:23
meikergolf pisze:Ten czujnik należy wymienić? Wychodzi też często błąd lambda 2.
jak są niesprawne to wymienić
Wróć do „Diagnostyka”
