Jakie cisnienie w cylindrach??
Passat_VR6
Szukałem troche na tym forum ale nic nie znalazłem, jakie powinno byc cisnienie w cylindrach, jakis stopien sprezania i cisnienie oleju w VR6?
alepka
tyle znalazłem w elsie czyli wynika ze nie moze przekroczyc 7.
‒ → Remove 0.3 bar oil pressure switch (brown insulation) and screw into the tester.
‒ Screw tester into the oil filter bracket in place of the oil pressure switch.
‒ Connect brown wire -3- of tester to earth (-).
‒ Connect diode test lamp V.A.G 1527 with aux. cables from V.A.G 1594 to battery positive (+) and 0.3 bar oil pressure switch (F22) -A-. LED must light up.
‒ Start engine and increase speed slowly.
At
0.15...0.45 bar
the LED must go out, otherwise renew 0.3 bar oil pressure switch.
‒ Connect diode test lamp to 1.4 bar oil pressure switch (black insulation) -B-.
At
1.2...1.6 bar
The LED must light up, otherwise renew 1.4 bar oil pressure switch (F1).
‒ Increase engine speed further.
At 2000 rpm and an oil temperature of 80 °C the oil pressure should be at least 2.0 bar.
At higher engine speed the oil pressure must not exceed 7.0 bar. If necessary renew oil pump.
At
0.15...0.45 bar
At
1.2...1.6 bar
