zaba84 pisze:A tak na marginesie moze jest jakis link po polsku??
Nie ma. To by bylo za proste
http://www.igorweb.org/equidec/Default.aspx
X0A = national sales program Germany
B0A = component parts set without country-specific design requirement
C5A = cast alloy wheels 7J x 17 offset 37 (3B0 601 025 M)
G0C = 5-speed manual transmission
H0U = tires 195/50 R 15 V
J0C = battery 220 A (45 Ah)
M5G = 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic, catalytic converter, base engine is T5C
Q1X = sports front seats with integrated storage trays
1AG = nine-inch power brake
1G6 = space-saving spare wheel
1ME = steering wheel (hollow rim)
1NL = covers for alloy wheels
3AD = outer right rear view mirror: convex, manually adjustable from inside
3BC = outer left rear view mirror: flat, manually adjustable from inside
T5C = components for, base engine, unit 051.2
0BB = rear stabilizer
330 = code not found
3U1 = foldable trunk cover
5J1 = rear spoiler
0G3 = gearshift linkage
8AC = radio "beta"
8GM = alternator 70A
8L1 = bright rod antenna
1H1 = load-sensitive proportioning valve
1K0 = without clutch actuation
1LF = disc brakes, front
3FE = electric slide/tilt sunroof with sun screen/sunblind
3YH = door pockets, front
1BA = standard suspension/shock absorption
		[img]http://img413.imageshack.us/img413/3990/naklejkalogopodpistt1.jpg[/img] Bye, bye Mk3...
