zmontowanie skrzyni basowej
od nie dawna jestem posiadaczem głośniczka sony xplod XS-L121P5W
dane:
XS-L121P5W
Speaker Woofer 30 cm (12 in),
cone type
Peak power 1,200 W
Rated power 350 W
Impedance 4 Ω
Sensitivity 89 ± 2dB (1 W, 1 m)
Frequency response 18 – 2,000 Hz
Mass Approx. 4.2 kg (9 lb 5 oz)
per speaker
Supplied accessory Parts for installation
i wzmacniacza również sony xplod XM-GTR2022 (i tu z danymi zaczynają się schody bo nie wiem w które wieżyc)
* Max Power 1200W x 1
* RMS Power output @ 2 ohms: 600W x 2
* RMS Power output @ 4 ohms: 250W x 2
* Variable 50-300Hz low pass filter with 12dB per octave slope
* High level sensing power on
* RCA and speaker level inputs; line level thru-put
* Low boost 0-10dB (40Hz)
* Dimensions: 15.8"W x 2.2"H x 10.8"D
bądź
* GTR Series 2-Channel Class A/B Car Amplifier
* RMS Power Rating:
o 4 ohms: 202 watts x 2 chan.
o 2 ohms: 250 watts x 2 chan.
o Bridged, 4 ohms: 500 watts x 1 chan.
* Max power output: 1200 watts
* OTL Output Transformerless Circuit Pulse power supply
* LED power indicators
* Bass Boost/EQ details (0-10 dB bass boost at 40 Hz)
* 2/1 channel operation
* Speaker-level inputs with signal sensing for automatic turn-on
* Preamp RCA outputs
* 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
* Removable top plate
* Heavy duty aluminum alloy inverted heatsink design for maximum heat dissipation
* Gold-plated RCA level inputs
* Gold-plated screw terminals
* Variable low-pass filter (50-300 Hz, 12 dB/octave)
* CEA-2006 compliant amplifier
* Frequency response: 20-20,000 Hz
* Dimensions: 10-7/8"D x 15-7/8"W x 2-1/4"H
* 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
* 1-year SonicElectronix.com warranty
bądź
Features:
Class A/B
600W x 2 Max Power Output
202W x 2 into 4 ohms, 20Hz-20kHz, 1.0% THD
Variable 50-300Hz Lo-Pass Filter
-12dB/oct Selectable Slope
250W x 2 into 2 ohms, 20Hz-20kHz, 1.0% THD
Specifications:
Max Power (Watts): 1200
Ad Hoc Power into 4 ohms, THD%: 202
Ad Hoc Power into 2 ohms, THD%: 250
Bridged into 4 ohms, THD%: 500
Signal to noise ratio (dB): 93dBA
Frequency Response (Hz): 5-50kHz
Current Drain at rated output (A): 48A
Width (inch): 15.8
Height (inch): 2.2
Depth (inch): 10.8
i moje pytanie jest takie jaka skrzynie zmontować czy ma być zamknięta bass refleks czy jaka
i jak obliczyć odpowiedni litraż pod ten głośnik
mam skrzynie ale coś z nią jest nie tak a dokładnie z wyjściem powietrza tam gdzie jest ten plastikowy "wyfuk" tak jakoś dziwnie świszczy i wszystko psuje
typ muzyki przeważnie RAP, RNB, ogólnie czarne brzmienia z dobrym basem :]
dane:
XS-L121P5W
cone type
Peak power 1,200 W
Rated power 350 W
Impedance 4 Ω
per speaker
bądź
* RMS Power Rating:
bądź
Features:
Class A/B
Specifications:
Width (inch): 15.8
Height (inch): 2.2
Depth (inch): 10.8
GrabarZ
teraźniejsze A3 8P 3.2 Quattro
http://forum.vwgolf.pl/viewtopic.php?f=91&t=525739
moje byle mk4 4motion
http://forum.vwgolf.pl/viewtopic.php?t=329054
- ozyrysh
- kieroVWca boroVWca
jesli głośnik jest nowyto jeszcze sie nie rozchodził i nie dawaj mu od nowosci w pyte bo go spalisz albo przepalisz i bedzie słabszy. Ja mam podobny głośniczek tylko zamiast 121 mam 126 i 380 w rms i skrzynka zrobiona ok 38 litrów taką jak zaceca producent. Jak chcesz to Ci mogę wymiary na PW wysłać. aha i producent przewiduje skrzynie zamkniętą ale jak zrobisz pare litrów większą to z pewnoscia bs nie zaszkodzi
kolego sprzęcik przyjechał do mnie z USA i był już używany
tyle ze biednie gdzie kolwiek znaleźć co kolwiek o tym głośniku w języku polskim
jak byś mógł to bardzo bym prosił o te wymiary
i jeżeli możesz wytłumacz mi co to jest bs i czym się rożni zamknięta od otwartej i od bassreflex
GrabarZ
Może czas zacząć czytać FAQ Nazara?
ozyrysh, powiedz czy czajnik też rozgrzewasz przed używaniem na maxa?
Ktoś kiedyś uwalił motyw że głośnik należy rozgrzewać i teraz tworzą się jakieś mity ... że spalisz cewkę , czy "będzie słabszy" (skąd Ty to wziąłeś
) . Nowy głosnik ma twardsze zawieszenie i należy je rozruszać ...sprawa czysto mechaniczna i żaden wygrzewanie cewki nie ma miejsca . Ona od nowości musi spełniać normy producenta i nic jej się nie stanie jak jej od nowości zapodasz "z głową" nominalną moc .
Co do obudowy ...trzymajcie się zaleceń producenta , bo zwiększenie za duże obudowy skutkuje zmniejszeniem wytrzymałości mocowej przetwornika.
- ozyrysh
nie chodzi mi o rozgrzewanie głosnika tylko o to ze jak jest nowy to przez np 5 h nie dawac mu na maxa tylko po troche. dobrzec go.
skrzynia zamknieta to taka ze nie ma bs czyli bass reflex
a otwarta to wlasnie bass reflex
dzięki za wymiary no a moja skrzynia jest prawie dwa razy dłuższa i na pewno wyższa i dla tego pewnie nie gra to tak jak ma grac
ale musi byc cos wieksza bo na goze pisze ze jest to 30l
kurcze mało osób się wypowiada na temat skrzyń a chciał bym się upewnić czy na pewno pod taki głośnik ma być skrzynia zamknięta czy aby na pewno nic się nie stanie głośnikowi itp
ozyrysh widzę ze jesteś z nie daleka bo w Mszanie dolnej mam rodzinę jak będę tam to się kiedyś zgadamy
GrabarZ
- ozyrysh
nie ma sprawy kolego. ja mam podobny głosnik i skrzynie zamknietą. jak podjedziesz to zobaczysz jak chodzi
