Witam koledzy potrzebuje trochę waszej pomocy chcę kupić mały wzmacniacz do mojego Suba Magnat B30 i nie wiem który byłby lepszy.
Dane Suba :
* WYMIARY GLOSNIKA 30cm
* MOC MAKSYMALNA 800W
* MOC NOMINALNA RMS 250W
* SKUTCZNOSC 91dB
* PASMO PRZENOSZENIA 50-250Hz
* WYMIARY 430x390x355
Dane Mac Audio MP2000 :
* tryb pracy: 1 lub 2 kanałowy
* moc RMS: 2 x 60W / 1 x 150 4 Ohm / 2 x 80W 2 Ohm
* moc MAX: 2 x 180W / 1 x 500 4 Ohm / 2 x 250W 2 Ohm
* pasmo: 5 - 50 kHz
* filtr low pass: 40 - 300 Hz
* filtr high pass: 40 - 300 Hz
* podbicie basu: 0 - 12 bD
* wymiary: 358 x 59 x 226 mm
Dane JBL CS300.1 :
* CS Series 1-Channel Class D Car Amplifier
* RMS Power Rating:
o 4 ohms: 200 watts x 1 chan.
o 2 ohms: 300 watts x 1 chan.
* Max power output: 460 watts x 1 chan.
* LED power and protection indicators
* Tuned Bass EQ (0-6 dB bass boost at 50 Hz)
* Single channel operation
* Preamp RCA outputs
* DC protection circuitry
* Variable low-pass filter (32-320 Hz, 24 dB/octave)
* CEA-2006 compliant amplifier
* Frequency response: 10-300 Hz
* Dimensions: 12-11/16" L x 10-1/4" W x 2-3/16" H
* 8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
* 1-year SonicElectronix.com warranty
Mac Audio MP2000 czy JBL CS300.1
karolekust
karolekust
