Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZ5B010894
Model Designation golf 1.9
Model GOLF
Date of production 14.06.2004
Model year 2005
Sales type 1K1031
Engine code BKC
Transmission code GQQ
Axle drive 5S
Interior trim code HA
Roof color Z4
Exterior color / Paint Code Z4 / C9Z
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Additional tires (winter tires) 2WA Without additional tires
Additional warning lights 9TC Additional reflectors (door area)
Air bag 4UF Driver's and front passenger air bag with front passenger air bag deactivation
Air duct, front area VK0 Air duct, standard
Antennas 8ZH Antenna for AM/FM reception, "diversity"
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H0 Without backrest release for front seats
Base engine T71 4-cylinder diesel engine 1.9 L unit 03G.1
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake type, front 1ZF Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JB Standard bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Center armrest 6E3 Front center armrest
Center rear seat belts 3C7 3-point seat belt for center rear seat
Child seat anchor, front 3G0 Without child seat anchor front (ISOFIX)
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FB Body-colored exterior mirror housings
Control number (no PR-Family) S0T Pre-production series/SOP next MY
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T2 Cruise control system (CCS) electronic
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A2 4 doors
Drive layout 1X0 Front wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GG Emission standard EU4
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine specifications D3W 4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system Base engine is T71/TG0/TD0/T5X
Equipment levels A8B Basic equipment
Exhaust tailpipe 0P0 Rear exhaust tailpipe (standard)
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WA Without front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Front seat, left 3TB Standard seat, front left
Front seat, right 3SB Standard seat, front right
Front stabilizer 0AD Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Fuel systems 0F8 Cooled fuel system for diesel engine
Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C05 Operating permit, alteration
Generators 8GU Alternator 140 A
Glove compartment 4Z3 Lockable glove compartment door, with light
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AP Climatic air-conditioning system (semi-automatic)
Horns 8Y0 Single-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5TC Without decorative inserts
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Instrument inserts U5A Instrument insert, km/h speedometer
Interior light in foot area 6T0 Without interior light in footwell
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SB Vanity mirror left
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FC Brussels manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 1DG Nameplate set "TDI"
Navigation device 7Q0 Without navigation device
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Owner's manuals 0VH Information kit in Dutch
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL1 Extended pedestrian protection measures
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Protective side molding 4B1 Protective side molding
Radiator grille 6KG Radiator grille
Radios 8AA Without radio
Reading light 8S1 Reading light front
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q6 Three rear headrests
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Rear stabilizer 0BD Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Refrigerator 1W2 Glove compartment cooling system
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TB Vanity mirror right
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Rough-road/sports version 2UA Standard design
Safety headrest system 3K1 Safety headrest system
Scuff plates 7M0 Plastic scuff plates in door apertures
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat belt check 9P3 Seat belt reminder, electric contact in buckle
Seat covering N4C Fabric seat covering
Seat heater 4A0 Without seat heater
Shock absorption, chassis, front G02 Front shock absorption
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X3 Side air bag front with curtain air bag
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JA Non-smoking package
Socket 7B0 Without socket
Spare wheel/breakdown set 1G8 Breakdown set
Speaker installation 8RL 6 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special editions E0A No special edition
Special labels/plates 0SE Labels/plates in Dutch
Steering 1N3 Speed-related variable steering assist (Servotronic)
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 1MA Steering wheel
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Telephone/telematics 9W0 W/o car phone preparation/installation
Tire pressure warning light 7K0 Without tire pressure warning light
Tire suppliers V0A Tires w/o specification of tire brand
Tires H7F Tires 195/65 R15 91H
Tool kit and jack 1S1 Tool kit and jack
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0C 5-speed manual transmission
Trunk sill protection 2P1 Plastic trunk sill protection
Type approval countries/countries with special requirements B31 Type approval the Netherlands
Vehicle class differentiation units/platform components 0HA Vehicle class differentiation 1K0/5K0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L07 Suspension range 07 installation control only, no requirement forecast
Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
Wheel covers 1NC Full wheel covers
Wheels C8V Steel wheels 6J x 15
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PH1
PR1
Child seats QA0 Without child seat
Chrome work package QJ0 Without aluminum/chrome work package
Compass/traffic sign display QR0 Without compass/traffic sign display/ traffic signs recognition
Drawers under front seats QN0 Without drawers under front seats
Nameplates for sales name QD1 Nameplates for sales name
Service interval prolongation QG1 Service interval prolongation
